Another "no audio devices"
Just downloaded 2.4.2
Running Swedish W10-64 Pro v2004 (19041.508)
Windows Feature Experience pack 120.2212.31.0
System is
MSI MEG Z390 ACE (MS-7B12 Rev1.0
Bios 1.90
CPU i9-9900KS
32 G RAM
Radeon RX590
Sound Realtek HD Universal & Nahimic Driver
All drivers are latest updates.
Windows is laterst update
So, what to do
Read the FAQ, but, I have all the latest drivers, and they are working with all other software, sound/video editors and so on.
Do you have any “virtual” audio devices installed? If so, try temporarily removing them.
It does not look that way
“Elgato Game Capture” ?
USB Video capture card.
Where do you see “Game Capture”?
Nahimic mirroring device ?
I didn’t, but “Elgato Game Capture” is the only time that I’ve seen an Elgato device listed.
Apperantly it is a
mirroring device is an audio device supporting the Sound Sharing feature. The sound sharing allows you to listen to your pc audio with 2 bluetooth headset at the same time.
What happens if you disable that device?
Disabled taskmanager, no change.
There’s clearly something about your setup that PortAudio does not like, but I don’t know what it is. It doesn’t help that I don’t speak Swedish.
You could try Audacity 2.3.3 (it uses an older version of PortAudio)
It’s available here: https://www.fosshub.com/Audacity-old.html
Well, ok, have to check this later, out for a business trip for a few weeks, I’ll be back.
