Hi,
I am using:
Mac OS 10.8.5
Audacity 2.0.4, via the Installer
As will shortly be obvious, I don’t know much about working with audio though I am usually pretty good with computer stuff, so thank you for the help.
I recorded several tracks over two days. The second day the person whose singing I was recording held the mic to close. The first day’s tracks are on the soft side, the second day’s on the loud side; the tracks for the same day, though, are at about the same recorded volume. I will accept some of the distortion, but I want to bring the volume of the two days to about the same level.
Every time bring in a track, and pull up the Effect>Amplification, it seems to be at a different level. So, based on two test tracks, though initially I thought I would amplify the Day One tracks to 18db and reduce Day Two to -11, this doesn’t even work consistently on the same track. Now that I am totally confused, how do I accomplish the above goal (in bold) using no more than about 3 steps per track?
Thank you!
