I am connecting keyboard to PC and recording is fine but sound is very quiet.
I have fined tuned loudness of keyword and tried to use amplifier funcion on audacity.
I can make quieter but not louder.
I got dB 24.3 and when I increase number, OK button is disable and I cannot save this.
Any help on this?
Thanks in advance.
Amplify will refuse to work if any part of the blue waves try to go over maximum up and down. You can force it to work by checking “[X] Allow Clipping,” but that means some part of the performance will be distorted by getting too loud.
How are you connecting the keyboard?
I use the Headphone connection on my keyboard and my computer has a stereo Line-In (older Mac). If your computer doesn’t have that, you can use a Behringer UCA-202 to adapt a stereo keyboard (or mixer in this case) to a computer.
You can use the headphone connection on the UCA-202 for headphones or a connection to a music system. It has its own volume control.
