AMD compatibility
Hi, can someone please advise as to whether Audacity is 100% compatible with a PC running an AMD processor. I will be using either a Focusrite Scarlett or PreSonus interface but I need to build a new computer and I’d like to go with AMD if Audacity is compatible.
Thanks.
Yes.
The [u]download page[/u] says:
Machine requirements
A CPU that supports SSE2 is required (any CPU made after 2003 should support this). Please use the legacy Audacity 2.0.6 version if your machine lacks SSE2 support.
