A friend sent me 35 minutes of audio (below is just a tiny portion) that contains a buzzing/distorted effect on their voices and he asked if I knew how to fix it.
They have 11 more files that sound the same.
Is this something I can fix? If so, how might I do that?
The (60Hz+harmonics) mains hum can be reduced, but where the syllables are almost gone like “th” of “thousand”, that’s incurable in Audacity. AI toolsmay be able to reconstruct the faint syllables …
before-after Adobe Enhance
I had a buzz like that once on a vinyl transfer, and it turned out to be a loose ground wire on the turntable. Fixing the cable did more in five minutes than an hour of effects did. So before you spend too long cleaning, it might be worth checking if the buzz is in the recording itself or came from the setup that made it.
For the file you already have, the notch filter at 60 Hz is a good place to start, as Trebor suggested. Just do not expect it to bring back syllables that are buried under the distortion. If the words are still readable after a gentle pass, take that win and move on.
