Alot of static
I do alot of old records and i am working on some for a fallow who has cancer and i am running into a problem these albums has not been taken care of well and there is alot of static and i mean alot and i am needing help is there away of clearing it up or something i can get to clean them up where there is no problem i can clean up if popping not bad but these are bad help please
I would strongly recommend buying ClickRepair (which I use in conjuction with Audacity for LP transcription & clean-up). See this thread of mine: http://audacityteam.org/forum/viewtopic.php?f=28&t=1994
Is the record static-y,or is the audacity recording the only thing with static…? YOu might just have it way too loud! Try turning everything down a bit…
