allow links to Effects in the plug-in folder
I did some experimentation and found that on Windows, if you put a link to an effect (file–which resides on some other drive) in the plug-ins folder, the plug-in fails to be installed. What happens on Mac and Linux?
See this forum thread for details on allowing said links:
http://forum.audacityteam.org/search.php?keywords=with+.lnk+files+in+the+plug-in+folder
and a patch which works for Windows.
this patch is functionally the same but is more ready for the time when plug-ins/ might have sub-folders
loadEffectLinks2.patch (4.84 KB)
I have been informed that on Mac Audacity is not “well behaved” when dealing with links (called aliases on Mac).
Look here for programming details to resolve the problem:
http://developer.apple.com/library/mac/#documentation/Carbon/Reference/Alias_Manager/Reference/reference.html
as I have done with Windows.
Links to effects work in Linux (tested on LMDE 201109)
