I would like to have Some to help out to write script “after tone effect generator” please help with this project. Thanks I will have gratitude after this and share with everyone thanks
Trebor
March 15, 2023, 1:00am
2
Do you mean the audio-equivalent of a negative-afterimage ?
Negative afterimages are generated in the retina but may be modified like other retinal signals by neural adaptation of the retinal ganglion cells that carry signals from the retina of the eye to the rest of the brain.
Normally, any image is moved over the retina by small eye movements known as microsaccades before much adaptation can occur. However, if the image is very intense and brief, or if the image is large, or if the eye remains very steady, these small movements cannot keep the image on...
A Zwicker tone is a short-term auditory illusion which resembles tinnitus (ringing of the ears). It was discovered in 1964 by Eberhard Zwicker at Bell Labs. The Zwicker tone can be described as follows: while listening to broadband noise ("white noise") with a spectral gap, if it is switched off a faint tone lasting for several seconds can be heard. In the silence, most listeners hear a tone corresponding to the spectral gap. The pitch strength corresponds to the pitch strength of a pure tone
