In 15 years I’ve had several hard disks go south on me. I’ve learned to back up religiously, but every once in awhile… Is there a way to back up EQ profiles and other user data to a dedicated back-up file (hard disk or DVD or tape), so that I could insert the data into the appropriate Audacity directory after a clean reload?
The EQCurves.xml file is in the Audacity folder for application data. There is also EQBackup.xml in the same directory which is the previous saved state of EQCurves.xml.
