Adjusting or Removing Effects is not taking effect
When I select a track and add reverb and apply, I can hear the effect.
When I remove or reduce the amount of the effect, I am not hearing the change.
Are you using real-time effects?
– Bill
Thks Bill! Total noob here. I was just using the Audacity effects - did some reading about plugins. Is there an open source effects plug in you recommend?
What is your operating system?
– Bill
