Adjusting EQ on the timeline
Hi guys!
I have a rather simple need, and i’ve been looking my eyes out to find how to do it. In a piece of software that does way more advanced stuff, I cannot believe this is impossible.
I want to modify the amount of a frequency (just lo or mid or hi) gradually (like a fade, but just for a particular frequency).
What you do in other software (say, Ableton) - you switch on a control line on the waveform for, say, “low” - make your own points on it and drag them up or down to manually create a curve you need.
Similar how you would use envelope tool in Audacity to adjust your track volume.
I can imagine something like that can be achieved via Spectogram, but maan, that sounds way too complicated for such a simple task.
Hope someone can shed a light!
And happy crispy fall to you all :slight_smile:
Probably the easiest way is:
  1. Duplicate the track (command + D)
  2. Apply EQ to the duplicate
  3. Crossfade the two tracks (http://manual.audacityteam.org/man/crossfade_tracks.html)
So I cannot make a manual “zigzag” of the desired frequency if i want to? I thought it’s something that many people would need? I guess not, then :smiley:
Audacity doesn’t do much in real time. You can create the tracks as above and zig zag back and forth in post production with the Envelope Tool.
http://manual.audacityteam.org/man/envelope_tool.html
Thank you so much for such fast answers!
And thank you for the big work developing all this!
Yes you can, but that’s not what you asked.
By “Zigzag” I presume that you mean something like this “High Pass Filter (LFO)” effect:
http://wiki.audacityteam.org/wiki/Nyquist_Effect_Plug-ins#High_Pass_Filter_.28LFO.29
Well high pass filter will still apply itself to the selected part of the track in a constant level.
What I want to do is, for example, use zero % bass for the first 10 seconds of the track, then increase it from zero to 50% over the course of the next 5 seconds, then keep it at 50%, then reduce again, and so on. I don’t need to listen real-time to what i’m doing, just be able to see the visual representation on the timeline somehow. But I understand, this is not a feature, no problems!
You could use the envelope tool *http://manual.audacityteam.org/man/envelope_tool.html) to control how much of each track:
thanks for the hack! :slight_smile:
