Adding to the end.
I have a recording and I simply want to "record over the last 5 seconds with something different. How does this work? I seem to always take myself back to the beginning
Audacity always records on a new track unless you do “append-record”
http://manual.audacityteam.org/o/man/transport_toolbar.html#record
If you click in the first track where you want to record new stuff then click “Record”, Audacity will record on a new track from that point.
If you make a selection in the first track then click “Record”, Audacity will record on a new track for exactly the time and location you have selected.
To record over the end of a track, first delete the portion you want to record over, then click “Record” while holding the Shift key, or press Shift+R.
Watch out for overdub and latency settings which may cause the newly-recorded section to be off by a fraction of a second. Of course, you can always use the editing and time-shift tools to put the newly-recorded section exactly where you want it.
There are several sections in the manual that will help you get started with recording and overdubbing.
http://manual.audacityteam.org/o/man/playing_and_recording.html
http://manual.audacityteam.org/o/quick_help.html
http://manual.audacityteam.org/o/man/tutorial_recording_multi_track_overdubs.html
http://manual.audacityteam.org/o/man/latency_test.html
– Bill
