Hello. I’ll explain this as best. I have 3 four minute files end to end and want to add an eight second file. As always, the file will snap to the left when added and it takes forever to move it to the end of the 3 files that are end to end, is there a way to add that small file without it snapping to the left ? Can it be added so that it will be at the end of the 3 files ?
Thank you.
I don’t have access to the program user interface right now, so I’m going by memory. You will have to adjust.
Click the Selection menu, then click Select All.
Click Tracks, then click Align End To End.
Here’s the situation, I’ve mixed 3 songs (all drag & drop), I want to add a voice over to the beginning of the 3rd song, again drag & drop. When I add the voice over file (8 sec) it will snap to the beginning and I have to drag it along to where I want it, which takes time. Similarly, if I have 10 songs mixed and want to drop a jingle at the beginning of the 9th song, it’s a nightmare trying to drag it all the way down.
Sorry, aligning end to end is not an option. Thanks for your message.
