I have recorded my voice. A song. but stopped before the last paragraph because I made a mistake. I have no problem deleting the defective part. But I don’t know how to start re-recording the end of the song at that point on the same stereo track that I am using rather than recording it on a separate track and then inserting it in the first track. I have tried to follow all instructions but don’t find an answer for this. Thank you.
Shift-R is Append Record. It will start recording at the end of an existing track.
Thank you very much, Kozikowski. Will try that. I’m a total tenderfoot with Audacity, which I had never used before. But so far I am satisfied with it. Orlando.
