Adding a new feature
I have Windows 7 Home Premium 64 bit. I am using Audacity 2.1.0
I would like a bin I could load effects into separate from the effects menu. EG.
Using the Hard Limiter then the Amplify requires some scrolling. If you want to redo these effects, (top of menu) you still have to be at them.
How many in the bin? Four would be enough for what I do.
Thank you.
The developers are looking toward making the Effect menu customisable in future releases of Audacity, but that could be a way off yet. In the meantime you could create keyboard shortcuts to those effects that you need to access regularly. See: http://manual.audacityteam.org/o/man/keyboard_preferences.html
Thank you very much, that will do splendidly.
Cheers.
The other trick you can use when in the long effect menu is to type the first letter of the effect you require …
