Add silence to the end of multiple labels
II have audio files of 5 minutes long, that I cut into different smaller tracks, using the add label feature and export. Each track is about 10 seconds long, so about 30 tracks per audio file. However I want to add 30 seconds silence to the end of each track I am going to export, is there an easy way of doing this, rather than cutting and pasting or manually adding silences, then having to select the audio and the silence to label for export?
