Add several effects at once
Hi there! I’m doing some trailer voice work and I need to apply:
-pitch -bas boost -AUDelay and gain on all my recordings.
Is there a way to to this automatically using one button press? The recordings all use the exact same settings.
Thanks.
I’m going with no. The latest Audacity has a batch command called chains, but it’s very basic and you can’t arbitrarily select what goes in it. It doesn’t learn what to do like the one in Photoshop.
Using “Chains”
-pitch -bas boost and gain - Yes
-AUDelay - No
