Add realtime effects automatically to new projects
I’ve started using realtime effects like a compressor to my voiceover recordings. Is there a way to create default effects so I don’t have to set them up for each new chapter?
What you could do is make a “template project” with the tracks and effects set up, and use that as a basis for the future recording. Only thing to remember here is to “save as” early so the template project stays without content.
Ah, I see what you’re saying. Good idea. I’ll do that. Thanks.
