ADD / DELETE COMPLEMENTS
When using add / remove plugins, once the program executes the action, the distribution of the toolbars is de-configured. They fall out of the ergonomic position that the user chooses. Is this also a program failure?
Sorry but I don’t understand what you mean.
Which version of Audacity are you using?
Which version of Linux?
Perhaps a screenshot would help to make it clear what you are describing.
Sounds like this “moonphase” problem …
https://forum.audacityteam.org/t/audacity-buttons-mess-up/44559/4
Si. Eso es lo que me ocurre.
Yes. That is what happens to me.
I’ve been getting that today with 2.2.0 RC1 :confused: :unamused:
Peter
