add build date to log
post 2.0.0
in audacity.h ~ line 41, make beta & “stable” lines end with TDATE like “alpha” does (which adds the BUILD date–and thus some commit version info); also change the trailing - (dash) to a space–it looks better IMVHO:
old:
#if IS_ALPHA
   #define AUDACITY_SUFFIX wxT("-alpha-") __TDATE__
#elif (IS_BETA)
   #define AUDACITY_SUFFIX    wxT("-beta")
#else
   #define AUDACITY_SUFFIX    wxT("") // for a stable release
#endif
new:
#if IS_ALPHA
   #define AUDACITY_SUFFIX wxT("-alpha ") __TDATE__
#elif (IS_BETA)
   #define AUDACITY_SUFFIX    wxT("-beta ") __TDATE__
#else
   #define AUDACITY_SUFFIX    wxT(" ") __TDATE__ // for a stable release
#endif
Can you say why? There is a policy not to release Audacity with the same version number and different contents (alphas are not strictly “releases”).
There may be a better case for having the date of releases shown on the Audacity downloads pages.
The devs would really like to be able to ID the commit revision number for some bug reports. Search Bugzilla for “commit”–I asked if there was a way and got “No, but it sure would be nice”. Having the build date on the betas (the “stable” is well known but you might as well have it for the sake of completion) as you already do on the alphas (it is part of the string which gets put at the top of the log) would help pin it down to a single day. That way parsing the commits would be a whole lot simpler.
It is super easy to have Subversion doing it for you.
svn propset svn:keywords "[Rev|Id|Date|Author|URL]" file
Then add
$Rev|Id|Date|Author|URL $
to the file and commit.
$ vi myfile.txt
>   $Rev: $
$ svn ci -m 'Add revision id to file' myfile.txt
$ less myfile.txt
> $Rev: 768 $
Same with the other tags of Id, Date, Author, URL
Ragnar
I do not see how the user in the field can then tell the dev what the commit revision number is. I think your example adds a revision number to a source file; they want a revision number on the executable and a way the user can report it in a bug report.
If the source file in question is AboutDialog.cpp:
EDIT: Oops, I was too fast! :blush: That will only show the revision when AboutDialog.cpp was last changed.
You’ll need svnversion and a bit of external processing to get the global revision number into your file.
Ragnar
That was my thought as well–the devs are not going to edit in something each commit. With adding the build date automatically they get very close and it shows in the Log.
Bugzilla gives too many results for “commit”.
My recollection was that Leland and I wanted to add revision number (to alphas) and Vaughan (or someone) did not, even if it could be done.
But same question - don’t we know the commit number of a release? I do.
Certainly, because of the freeze. But there will be nightlies going forward, right? And if those nightlies had at the top of the log the latest commit number, I’d know for sure what I’m testing.
As an aside, I can’t see the date/time stamp of commits in Google Code. All I can see is e.g. “Today (26 minutes ago)” or “Yesterday (27 hours ago)”. I can infer from that the UTC of the commit, I suppose, but having it displayed would be much easier, and deal with the issue that was raised when I commented on bug 334 http://bugzilla.audacityteam.org/show_bug.cgi?id=334#c45 .
– Bill
Yes, and they will be alphas (I presume) which already have TDATE appended to AUDACITY_SUFFIX.
Yes and that was what I was asking for (for the nightlies) but it cannot currently be done. Ed’s change does not add the svn revision number anywhere.
Rather than look on http://code.google.com/p/audacity/source/list , the answer would be to subscribe to audacity-svn_AT_googlegroups.com (or just look at it online ).
True, it just extends the ability to tell the build date to beta (and “stable” though of little interest there). Deducing a nightly’s commit revision number from it’s build date is not too hard I would suppose.
In re. searching the Bugzilla, sorry , can be of little further help, I recall it as Richard but maybe Leland who bemoaned the lack.
BUMP - does this need trnsferring to Wiki>Pending Feature Requests?
Build date is already added to alphas and is un-necessary for releases. It seems that it isn’t possible to programmatically add the svn revision number to About Audacity (and so to the top of the log). So I don’t think this is for PFR’s.
Of course the person packaging the “Nightly Builds” (myself for Windows and Paul for Mac) can manually add the svn revision number to the name of the file to be downloaded (or somewhere else). I don’t think it would be acceptable to manually mess with Audacity.h each time to get the revision number in About Audacity and log. Paul might be able to script the file name to also include the revision number - I’ll ask him.
Thanks for the heads-up Gale.
Peter
