ACX Check
Suddenly my ACX Check won’t work. It shows up in my list of plugins but it says it is disabled. I click to enable it and ok. Then when I go to find it under Analyze, it doesn’t appear. I then go to my list of plugins again and it shows that it is still disabled.
And it’s been working, right?
Did Windows do an update in the middle?
Try a clean restart of Windows. Shift-Shutdown. Not plain Shutdown and not Restart. That takes longer and does a more complete “cleaning” of Windows.
Did you get the plugin from here?
https://wiki.audacityteam.org/wiki/Nyquist_Analyze_Plug-ins#ACX_Check
When was the last time you did an exhaustive virus check; the one that runs all night?
