Analyze> ACX Check (using Nyquist file ACX-Check.ny) started running erratically this week, approx. 9/1/21 after running OK since the new Nyquist file was installed at Audacity forum contributors’ suggestion in January 2021. it works OK on some tracks in some projects but yields only errors on others, including projects and tracks where it worked OK until this week. An example of error results is shown below.
Even when ACX Check yields plausible numerical results on a track, clicking OK in the ACX Check results box now brings up a Debug Output box, with no content. The Debug Output box never appeared before.
What do you make of this problem and how do you suggest fixing it?
Sample ACX Check Error Diagnostics:
ACX Check results box showed only: “Nyquist returned the value 1”.
Then clicking OK brought up a Debug Output box with the following:
[Then clicking OK yields the following]
error: invalid dotted pair
1> error: unbound variable - UDITION
if continued: try evaluating symbol again
2> " 'NAME)\n(putprop '*TRACK* "
2> error: unbound variable - WAVE
3> " 'TYPE)\n(putprop '*TRACK* "
3> error: unbound variable - WAVEFORM
4> " 'VIEW)\n(putprop '*TRACK* 1 'CHANNELS)\n(putprop '*TRACK* T 'SPECTRAL-EDIT-ENABLED)\n(putprop '*TRACK* (float 0.0) 'START-TIME)\n(putprop '*TRACK* (float 51.318435) 'END-TIME)\n(putprop '*TRACK* (float 1.0) 'GAIN)\n(putprop '*TRACK* (float 0.0) 'PAN)\n(putprop '*TRACK* (float 44100.0) 'RATE)\n(putprop '*TRACK* 24 'FORMAT)\n(putprop '*TRACK* (list (list (float 0.0) (float 51.318435)) ) 'CLIPS)\n(putprop '*SELECTION* (float 0.691831) 'PEAK)\n(putprop '*SELECTION* (float 0.691831) 'PEAK-LEVEL)\n(putprop '*SELECTION* (float 0.073661) 'RMS)\n(setf *tracenable* T)\n\n\n\n\n\n\n\n\n\n\n\n(defun getfloor ()\n ;; Calculate RMS where rate=10 Hz, window-size=0.4 seconds.\n ;; Return the lowest 0.4 to 0.5 s in the selection.\n (let ((floor 999)\n (window-size (round (* 0.4 *sound-srate*)))\n samples)\n (setf *track* (s-rms *track* 10 window-size))\n ;; Calculate new length in samples without retaining samples in RAM.\n (setf samples (truncate (* len (/ (snd-srate *track*) *sound-srate*))))\n (do ((val (snd-fetch *track*) (snd-fetch *track*))\n (count samples (1- count)))\n ((< count 4) floor) ;stop at last full window.\n (setf floor (min floor val)))))\n\n\n(defun s-rms (sig &optional (rate 100.0) window-size)\n ;;; Like RMS function but also supports stereo sounds\n ;;; Stereo RMS is the root mean of all (samples ^ 2) [both channels]\n (when (soundp sig)\n (if window-size\n (return-from s-rms (rms sig rate window-size))\n (return-from s-rms (rms sig rate))))\n (let (left-ms right-ms rslt step-size)\n (setf step-size (round (/ (snd-srate (aref sig 0)) rate)))\n (unless window-size\n (setf window-size step-size))\n (setf (aref sig 0) (mult (aref sig 0)(aref sig 0)))\n (setf (aref sig 1) (mult (aref sig 1)(aref sig 1)))\n (setf left-ms (snd-avg (aref sig 0) window-size step-size OP-AVERAGE))\n (setf right-ms (snd-avg (aref sig 1) window-size step-size OP-AVERAGE))\n (s-sqrt (mult 0.5 (sum left-ms right-ms)))))\n\n\n(defun track-rms ()\n ;;; Teturn the RMS of *track*.\n ;;; Stereo RMS is the root mean of all (samples ^ 2) [both channels]\n (let ((rms (get '*selection* 'rms)))\n (if (arrayp rms)\n (let ((left-mean-sq (* (aref rms 0)(aref rms 0)))\n (right-mean-sq (* (aref rms 1)(aref rms 1))))\n (sqrt (/ (+ left-mean-sq right-mean-sq) 2.0)))\n rms)))\n\n\n(defun check-peak (peak)\n ;;; Return Pass, fail or warning.\n ;;; Peak too low is unlikely, but indicate the problem.\n (if (> peak -2.99)\n "
4> error: unbound variable - FAIL
5> error: unbound function - TOO
6> "\n (if (< peak -6)\n "
6> error: unbound variable - WARNING
7> error: unbound function - TOO
8> "\n "
8> error: unbound variable - PASS
9> ")))\n\n\n(defun check-rms (rms)\n ;;; Return Pass or Fail.\n (if (> rms -17.99)\n "
9> error: unbound variable - FAIL
10> error: unbound function - TOO
11> "\n (if (< rms -23)\n "
11> error: unbound variable - FAIL
12> error: unbound function - TOO
13> "\n "
13> error: unbound variable - PASS
14> ")))\n\n\n(defun check-floor (floor)\n ;;; Return Pass, Fail or warning.\n ;;; Room tone is expected - warn if extremely low.\n (if (> floor -59.99)\n "
14> error: unbound variable - FAIL
15> error: unbound function - TOO
16> "\n (if (< floor -90)\n "
16> error: unbound variable - WARNING
17> error: unbound function - TOO
18> "\n "
18> error: unbound variable - PASS
19> ")))\n\n\n(defun check-rate ()\n ;; Return warning or empty string.\n ;;; ACX require 44100 sample rate.\n (if (/= (round *sound-srate*) 44100)\n "
19> error: unbound variable - |nnWARNING:|
20> error: unbound variable - ACX
21> error: unbound variable - REQUIRE
22> 44100
22> error: unbound variable - HZ
23> error: unbound variable - SAMPLE
24> error: unbound variable - RATE.
25> "\n "
25> "))\n\n\n(defun check-length ()\n ;;; Return warning or empty string.\n ;;; ACX require running time no longer than 120 minutes.\n (let* ((start (get '*track* 'start-time))\n (end (get '*track* 'end-time))\n (dur (- end start)))\n (if (> dur (* 60 120))\n "
25> error: unbound variable - |nnWARNING:|
26> error: unbound variable - ACX
27> error: unbound variable - REQUIRE
28> error: unbound variable - RUNNING
29> error: unbound variable - TIME
30> error: unbound variable - NO
31> error: unbound variable - LONGER
32> error: unbound variable - THAN
33> 120
33> error: unbound variable - MINUTES
34> "\n "
34> ")))\n\n\n(defun selection-too-long ()\n ;; Return true if selection is more than "
34> NIL
34> error: misplaced right paren
35> error: unbound function - SELECTION-TOO-LONG
36> 35> 34> 33> 32> 31> 30> 29> 28> 27> 26> 25> 24> 23> 22> 21> 20> 19> 18> 17> 16> 15> 14> 13> 12> 11> 10> 9> 8> 7> 6> 5> 4> 3> 2> 1>
