Hello!
I have two questions:
Is it possible to extract a track temporary and put it into another wave editor like Goldwave? In Sonar or Reaper I can take a track and put it into Goldwave to add other FX, that are not included or more simple to handle. It could be good for fast editing of a track, without opening several Audacity Windows, E. G. fast inserting of more files after another. Alternatively:
How can I as a blind user import a file on specific time? When I set the play cursor to a point with Shift+A and execute import file, it is at the beginning of my project, but not on my play cursor. How can I do that?
Thanks alloot. Alex
