Hello , i would like a script for audacity
I would like it cuts the sound at the beginning and the end and that the sound normailse
Sorry for my English i’m French
Thanks You !
Make sure you have latest Audacity 2.0.5: http://audacityteam.org/download/windows .
Download the “Trim Silence” Nyquist plug-in: http://forum.audacityteam.org/download/file.php?id=6138 . Put the .ny file in the “Plug-ins” folder inside the Audacity installation folder then restart Audacity.
File > Edit Chains… then add Normalize and Trim Silence to a chain. Add an Export command to the chain if you want to apply the Chain to a group of imported files. See: http://manual.audacityteam.org/o/man/edit_chains.html .
Thanks You a lot
I win a lot of time with your method !
