a question about a message
hi after I edit with audacity I go to hit the exit and I get a message saying “save chances before exiting”…i had already saved the file that I wanted to save…whats this about…and what if I don’t save this way can I by pass it or not use it?
lenny
Audacity insists on trying to Save an Audacity Project whatever else you were doing. I don’t think there’s a way to bypass the warning.
hi
I looked back at the files ive already done and there in my documents saved with the changes ive made to them…
lenny
Oh, it does work, but Audacity considers any product or show incomplete unless you also save a Project.
And yes, I do wish it acted like other programs which accept my product decision as final.
ok thanks koz…
lenny
What should happen, in your opinion?
gale im with koz on this…
lenny
Yes, but what does Koz suggests happens? Users often import files into Audacity then delete them, or press the red X on the window thinking that saves the recording. In those cases, Audacity has to ask.
yep…it happenes to me too that’s why I started this thread,
We know that it happens for you. That warning message is supposed to appear. It is the “last chance reminder” that the current state of the project has not been saved.
If you don’t want to save the project, click the “No” button (don’t save).
ok…
