A corrupted aup file that wont open
When i try opening the project it cant find folder
Tried everything even to restore it might have to redo it
If you are trying to open a pre-3.0 Audacity .aup project, note that it comes in two parts. There is an project file, say “xyz.aup” which contains a description and all the structural information of the actual audio which resides in the “xyz_data” directory.
Current versions of Audacity are able to open older .aup projects if the _data folder is located in the same directory and has the same name appended by _data. So the “xyz.aup” and the “xyz_data” directory both need to be in the same directory.
