Hi folks
After a Windows update on my laptop I found that my mic, which is connected to my Audiobox ad/da converter does not appear as an input device on my Audacity desktop. I checked Windows Sound settings and the AudioBox is listed as the default input device. Running a troubleshoot tells me that there are no problems with the device. Audiobox is listed however as my default listening device in Audacity. I’ve tried restarting the computer and even reinstalling Audacity, to no avail. Most likely I’m doing something wrong here but I’m not sure what that is. Can you help
Audacity 2.4.2
Windows 10
Presonus Audiobox USB
Audio Technica AT4040 mic
Thanks in advance
Bob H
