Hi,
using windows with wasapi for ages but then 9996 error pops up. Using loopback preamp/speakers just trying record from web radio as per and boom, or not, no joy.
Any suggestions ?
Thanks in advance
Jon
Someone will correct me, but 9996 error is āI canāt find a drive.ā Are you trying to use a Cloud Drive with Audacity? Stop doing that. Always use internal drives with Audacity.
The problem isnāt that it fails, the problem is that it doesnāt always work.
Thanks for the reply, youāre correct about error message but Iām using internal drive only, so the error is baffling?
Anyone have a response?
TIA
Same issue here, on an old Windows 8.1 laptop that I sometimes use, I now get the same error that you reported, when I try to record from āloopbackā (on laptop internal or USB audio device). The problem apparently started with the recent upgrade. I donāt need the new versionās features, so I plan to downgrade in hope to recover loopback recording functionality on this old laptop.
I tried older versions and got same error, so you maybe out of luck there too.
Dāoh! ā Iāve just now returned to my project, and quickly found my fix. Iād forgotten that I had changed Audacityās Recording Channel setting to Mono for a previous project. Iāve reset it to Stereo, and loopback recording now works without error. ā If that doesnāt help in your case, check also some other settings that are mentioned on the relevant help page.
