Hello.
This probably doesn’t effect newer versions of Audacity/Nyquist, but I happened to
notice today while running tests for the UI of my new plug-in that if I entered the
number “55” into the UI, it would return the number “54”.
BTW: I’m using 126 on Vista64-bit
This only occurs for the number “55” as far as I know, all other numbers reported
correctly. In addition, if I change some of the other numbers in the other inputs,
it reports “55” correctly.
Not really a “serious” issue, but I found it interesting. Perhaps it’s that darn
USSA messing with me again.
I’m leaving my test plugin here in case someone wants to check it out…
prepzerotest.ny (13.4 KB)
