5.1 [SOLVED]
once,i’ve found a diagram,how to link the channels.now i cannot find it anymore.can someone help me to link channels for 5.1? which one is subwoofer?i see only the channels,but i don’t know which one is the right for fr,fl ,center…thanks
Enable “Use custom mix” in Preferences (https://manual.audacityteam.org/man/import_export_preferences.html)
Unfortunately this can be tricky because there are different standards for different formats, and not all players stick with the format specifications.
The channel order for WAV files is specified here:
https://docs.microsoft.com/en-us/previous-versions/windows/hardware/design/dn653308(v=vs.85)
Some other formats are listed here: https://en.wikipedia.org/wiki/Surround_sound
it’s not helping.i already used audacity to make 5.1 songs,and i know to enable and export wav,what i don’t remember is which channel is for subwoofer and which one is for tweeter.(ex: channel 6 (or4) is for subwoofer,channel 1 and 2 is for fr and fl…)
Have you tried reading the links that I posted?
thanke.first,one of the links was dead
Do you now have the information that you need? If so I’ll close this topic as “solved”.
yes .solved.thanks again.have a nice day
