4.0 problems I need fixed
Keyboard shortcuts missing
Fn + left arrow no longer sends the insertion point to the beginning.
Fn + right arrow no longer sends the insertion point to the end.
Shift + Fn + right arrow no longer selects from insertion point to the end.
Shift + Fn + left arrow no longer selects from insertion point to beginning.
I used those keyboard shortcuts a lot in version 3. They are also standard shortcuts on all of my other apps. I don’t like having to learn new ones just for your app. I have a hard time believing you couldn’t have maintained the old ones.
Playback often pauses at about the 4-second mark. Changing host temporarily fixes that but it eventually returns. Version 3 never had that problem. You really need to fix it in version 4.
I primarily use Audacity to prepare one-man quartet recordings. To synchronize voices I often paste in snippets of silence. In version 3 that was all I had to do. In 4.0, now I have to join clips after pasting.
In version 3 when opening the amplify page it would automatically highlight the amplify value so I only had to type in how much. In 4.0 I have to manually highlight the old value before I can change it.
The fact that the insertion point spans all tracks is both good and bad. It helps when I am syncing voice parts but it gets in the way when I want to know which track is actually selected.
I don’t have a need for any of the new features so I plan to continue using version 3 until you fix what is wrong on 4.
That’s my advice to everyone. Use 3.7.9 for work, but continue to check in with Audacity 4 and make the switch when and if AU4 meets your needs.
add in the lack of a single keystroke command to delete an entire track. CMD-0 used to do this, but it’s gone now.
I am also sticking with Audacity 3 (which is definitely one of the all time great programs ever written) for now.
