4.0.1 missing macro sound effects feature
I just installed 4.0.1 and while it looks slick, there doesn’t appear to be a way to apply a group of effects (macro) as we could do in the previous versions. I was able to actually name my favorite group of effects and easily apply them under that name. Will this feature be available soon? If not I have to go back to the previous version.
They’re working on it.
As always, my advice is to stick with Audacity 3. Check in with Audacity 4 now and then to see when and if it meets your needs.
Thanks billw58! It’s good to know that they’re aware of it and in the process of addressing it. I’ll be patient and just wait. I think for now I’ll just stick with the new version 4 as I did find a way to manually add my preferred effects one at a time.
