All -
I’m being offered a voice over job that is requiring the following technical output:
.wav format. 32bit encoding. 44.1KHz or higher, 48KHz preferred.
If I record and simply export using the 32 bit float wav standard, is this what is needed? I see under the WAV settings, there is:
Signed 32-bit PCM, 32-bit float, 32kbs G721 ADPCM, and 32kbs NMS ADPCM. Not really sure which delivers the requirement here. Any help or feedback is appreciated!
Kevin
