320Kps (SOLVED)
Is it possible for me to save a project as MP3 file at 320kps?
Sure! If you have LAME installed, you have access to all of the important LAME options, including 320kbps CBR (constant bit rate).
But, don’t use “Save”. To create/render an audio file (instead of a project file) go to File → Export.
:smiley: :smiley: Thank you. Its working fine.
