[3.7.1] Crash with external plugin
Good evening.
I use W11 23H2 22631.4751 and the latest version of Audacity (3.7.1) when I try to open an external plugin the system crashes and it only happens with an external plugin.
It is Nugen audio paragon, the same plugin is opened without problems with Adobe Audition, I have tried uninstalling both Audacity and the plugin and then installing again, the problem remains.
Any ideas?
Thanks
It’s a VST3 plugin, you access those via the realtime effects menu …
https://support.audacityteam.org/audio-editing/using-realtime-effects
Having said that, not all plugins work in Audacity. (Valhalla Supermassive does, and it’s free).
