3.4.1 compressing a clip then applying limiter moves the clip to the right
This happens after using 3.4.1 for < 15 mins. Reverting, saving, exiting, and reopening fixes it for a short time.
Sounds like this bug: Incorrect clip positioning when applying Nyquist effects · Issue #5573 · audacity/audacity · GitHub
Bug Report: Applying noise reduction to a clip repositions the clip right.
  1. Create vocal clip, normalize loudness.
  2. Highlight clip and apply noise reduction. Clip will be moved right and appears corrupt.
  3. Exit Audacity 3.4.1, reopen project, highlight same clip and apply noise reduction. Correct result (noise reduced, clip stays in same place) will occur.
