3.3 doesn’t show mic in devices
Need help with getting past error at start using 3.3
The microphone built-into your laptop or something else? If something else, tell us about your hardware setup.
Does Windows find it? Try Listen To This Device.
Check your Privacy Settings/Permissions.
And while you’re at it, disable any “Enhancements”. Windows is trying to help with communications but the “enhancements” can foul-up recording.
