3.3.1 hangs when openning this flac
As titled.
But “Sorry, new users can not upload attachments.”
As you knew,
Maybe it’s not really a FLAC? Check it with MediaInfoOnline.
Or sometimes FLACs get corrupted with the wrong kind of metadata tags. (MediaInfo won’t check that.) FLAC is supposed to use Vorbis Comments but sometimes people add ID3 tags and that can cause problems.
Try converting the file to WAV with Kabuu Audio Converter (or another 3rd party converter).
Maybe it’s not really a FLAC as the reason for hanging/frozen.
It happened a few times with any flac files in the fold, the solution: reinstall 3.3.1 and reset pref., and the flacs could be edited.
