3.2.2 Double Height Docking not working
I updated to version 3.2.2 a few moments prior to writing this post and as with any update it resets the toolbars. But this reset usually isn’t a problem as I could just correct them back to how I had them before but this time I can’t.
I usually have the Playback Toolbar be double the height by undocking, changing the height, and docking it again. But when do this with version 3.2.2 it resets the length and height upon redocking.
Also this problem seems to apply to every toolbar when you redock them.
Any help on why this suddenly doesn’t work would be appreciated.
Thanks in advance.
Yes this appears to be a regression on 3.2.1 and earlier - I will log this on Muse’s GitHub issues log later.
Peter
Logged as:
3.2.2 prohibits re-docked double-height meter toolbars - and reverts extended meter toolbar to default length on re-launch #4049
https://github.com/audacity/audacity/issues/4049
Good catch ImReallyFakeRight - many thanks for reporting this :slight_smile: :sunglasses:
Peter
