2 Mics
I have a question.
I recorded some words from 2 different computers with different mics. This resulted in 2 different sets of audio sounds. If I can use the words to make a sentence, you can tell which set they came from. Is there a program such as Audacity or a way to make both audio sets sound the same or similar?
Thanks.
To be clear here is a small example.
I recorded ‘apple’, ‘banana’, ‘orange’ on COMPUTER 1
I recorded ‘cat’, ‘dog’, ‘fish’ on COMPUTER 2
the ‘apple’ group audio all sound similar but different than the ‘cat’ group.
Even though it was my voice, they sound different depending on the mic and computer used to record them.
I want to make ‘apple’ sound similar to ‘cat’, like it was done using the same mic and computer. Of course I have tons of words i need to do. Easier to understand?
Thanks again.
Could you upload a short sample.
See here for how to upload a sample: https://forum.audacityteam.org/t/how-to-attach-files-to-forum-posts/24026/1
