Sometimes when pressing CTRL+SHIFT+E to export the project, I get the keyboard preferences window instead of the file export window. This seems to be triggered by using space bar to play/stop audio directly prior to issuing the CTRL+SHIFT+E shortcut.
Steps to reproduce:
- Record a few seconds of audio, or drag an audio file into Audacity.
- Press spacebar twice to start and stop audio playback.
- Press CTRL+SHIFT+E.
Result: Sometimes instead of getting the file export window, the keyboard preferences window pops up instead.
Expected result: CTRL+SHIFT+E should always bring up the file export window.
Here is a video showing the bug in action. My key presses are displayed at the bottom of the screen.
Notes:
- This bug seems to occur more commonly on my slower laptop than it does on my faster desktop PC, both running Linux.
- The bug occurred most frequently for me with the file export set to .WAV (16-bit), though that could just be coincidental.
- I can also reproduce the bug in a Linux VM running in VirtualBox. I cannot reproduce the bug on macOS, and I haven’t tried yet on Windows.
- The bug occurs in Audacity version 2.3.3 using either the .deb (via Panda Jim PPA) and FlatPak Audacity packages. Essentially, every build of Audacity 2.3.3 I have tested in any Linux configuration has exhibited the bug.
Here are the system configurations under which I have been able to reproduce the bug, all using Audacity version 2.3.3:
System #1: Custom-built desktop PC
- OS: KDE Neon 5.17 64-bit (Plasma Desktop 5.17.3, KDE Frameworks 5.64.0, Qt 5.13.2)
- Linux Kernel: 5.0.0-36-generic
- CPU: Intel Core i7-990x Bloomfield 3.46 GHz hexa-core
- RAM: 12GB
System #2: HP Pavilion m6-1035dx laptop
- CPU: AMD A10-4600M 2.3 GHz dual-core
- RAM: 8GB
System #3: VirtualBox VM running on system #1
- OS: Xubuntu 18.04 64-bit
