After installing 2.1.3 and going into Preferences, the Pref window seems to default to the original minimum size and as a result, the Functions are in view to the left, but the hotkey Assignments are WAY beyond the Pref window boarder to the right, making in necessary to `drag´ the Preferences window bigger or scroll the view horizontally. So the Perf window doesn’t retain its size and position?
The behavior in 2.1.2 was… the default Pref window would show both Functions and Assignments without dragging or scrolling. In other words the two columns were narrow enough to fit in the default Perf window frame. Is this true? or am I losing my mind?
-Ed
