I meant for example, try running some effects and see if you can still use the project window afterwards.
Similarly, try FIle > Edit Metadata…, Audacity > Preferences…, Help > Audio Device Info… and others. The problem may not be confined to the Plug- in Manager.
The cursor being the mouse pointer?
Yes, thank you. I can see that. wx Widgets 3 again, I assume, and it affects other toolbars in the upper tooldock area.
I think you will have to use keyboard shortcuts instead.
Not planned, but not unexpected. That is unlikely to be fixed for 2.1.2.
It’s also annoying that track focus is temporarily lost while dragging a slider.
Yes please I was going to suggest starting a new topic or topics if the Sound Activated Crashes are fixed as I think they are.
cmac185 wrote:
I’m not sure what you were referring to opening other dialog windows as a test. I don’t see any other ones other than the plugin dialog that can be opened from several menu items.
Ok. I’ve opened some, will try more.
cmac185 wrote:
In the process of editing a recording last night I noticed another issue.
You can reproduce it by having a recording displayed in the track display. Then click somewhere on the recording with the cursor
cmac185 wrote:
and notice that you can move the cursor with the arrow keys. Then either zoom in or out using the zoom tools from the tool bar. Now try to move the cursor with the arrow keys. You’ll find the cursor will not move anymore. Click somewhere else and now the arrow keys work. Do another zoom and you’ll find the arrow keys unresponsive again. This is on both 2.1.2A versions.
Ok, can do though the tools are handy. Hopefully a fix can be figured out.
cmac185 wrote:
Would you rather use another means to report suspected bugs than this forum thread? I was just thinking the topic is kind of changing.
Will do. The Sound Activated issues seem solid with your build.
Just an addition to the above post, I’ve tried a number of windows, effects and all seem to work fine now on your build. I haven’t had any crashes at all on Yosemite regardless of what I have done. The flashing is totally gone as far as I can see with 2.1.2. When I go back to 2.1.1 it flashes like before.
Tool Tips now work. I removed one tool bar and then restored it and then the tool tips started working. I suppose they may have started working earlier, but I probably would have noticed. Anyhow, thought you might be interested.
Another thing, regarding the arrow keys not working to move the track cursor, the issue is focus on the track. When the Zoom tool is used it changes the focus to the tool and does not return it to the track. If I switch to another app and back to Audacity the arrow keys are working and I can see the focus indicator around the track display which was not there after using the zoom tool. Hope this helps track down the issue if it hasn’t already been fixed.
I don’t think they are working anywhere near reliably enough to close http://bugzilla.audacityteam.org/show_bug.cgi?id=1201. If I quit Audacity, delete audacity.cfg, then launch Audacity, the tooltips never show up. The only way I can make them reliably appear is View > Toolbars > Reset Toolbars.
A fix has been made but the fix breaks (SHIFT +) COMMAND + F6 navigation ( http://bugzilla.audacityteam.org/show_bug.cgi?id=1203#c12 ) . Perhaps that does not matter too much, since most accessibility is broken by wx3 on Mac in any case. No further fix has been offered yet.
