2.1.1 Crash on startup - Yosemite 10.10.4
I had an older audacity installed (2.1.0 I think) that was working, but occasionally crashed during usage. Restarting usually allowed me to finish what I was doing.
I tried to install 2.1.1 ( downloaded .dmg) clicked on downloaded file, drag/drop Audacity to Applications, watched it copy files, but when I try to start Audacity it crashes immediately with a crash report being generated.
I have tried removing the audacity.cfg & the othe .cfg file mentioned in other posts but still get the following crash on startup:
Process:               Audacity [873]
Path:                  /Applications/Audacity/Audacity.app/Contents/MacOS/Audacity
Identifier:            net.sourceforge.audacity
Version:               2.1.1.0 (2.1.1.0)
Code Type:             X86 (Native)
Parent Process:        ??? [1]
Responsible:           Audacity [873]
User ID:               502
Date/Time:             2015-07-22 21:31:54.095 -0400
OS Version:            Mac OS X 10.10.4 (14E46)
Report Version:        11
Anonymous UUID:        EAEC1889-BBEE-1D77-89DB-552C15F8D61C
Time Awake Since Boot: 13000 seconds
Crashed Thread:        3  Dispatch queue: com.apple.root.default-qos.overcommit
Exception Type:        EXC_BAD_ACCESS (SIGSEGV)
Exception Codes:       KERN_INVALID_ADDRESS at 0x00000000e8240000
VM Regions Near 0xe8240000:
    Stack                  00000000bf800000-00000000c0000000 [ 8192K] rw-/rwx SM=COW
    Submap                 00000000ffff0000-00000000ffff1000 [    4K] r--/r-- SM=PRV  process-only VM submap
Thread 0:: Dispatch queue: com.apple.main-thread
0   libsystem_kernel.dylib        	0x94688a0a semaphore_wait_trap + 10
1   libdispatch.dylib             	0x9462587b _dispatch_semaphore_wait_slow + 289
2   libdispatch.dylib             	0x946256df dispatch_semaphore_wait + 37
3   libxpc.dylib                  	0x9401fe7c xpc_connection_send_message_with_reply_sync + 239
4   com.apple.CoreFoundation      	0x9960105e -[CFPrefsPlistSource sendRequestNewDataMessage:toConnection:error:] + 94
5   com.apple.CoreFoundation      	0x996006ea __50-[CFPrefsPlistSource alreadylocked_requestNewData]_block_invoke + 170
6   com.apple.CoreFoundation      	0x995f70ee _CFPrefsWithDaemonConnection + 366
7   com.apple.CoreFoundation      	0x996005f7 -[CFPrefsPlistSource alreadylocked_requestNewData] + 231
8   com.apple.CoreFoundation      	0x99601bb4 __alreadylocked_requestNewDataIfStale_block_invoke + 36
9   com.apple.CoreFoundation      	0x9945f4dc _copyValueForKey + 156
10  com.apple.CoreFoundation      	0x9945f426 -[CFPrefsPlistSource copyValueForKey:] + 38
11  com.apple.CoreFoundation      	0x99489f1c ___CFPreferencesCopyValueWithContainer_block_invoke + 44
12  com.apple.CoreFoundation      	0x9945e273 +[CFPrefsSource withSourceForIdentifier:user:byHost:container:perform:] + 1203
13  com.apple.CoreFoundation      	0x99489ea9 _CFPreferencesCopyValueWithContainer + 217
14  com.apple.CoreFoundation      	0x99489dbf CFPreferencesCopyValue + 47
15  com.apple.CoreGraphics        	0x98b96c0d load_allow_debugging_defaults + 64
16  libdispatch.dylib             	0x9461e0b5 dispatch_once_f + 251
17  com.apple.CoreGraphics        	0x98b96bc8 copy_local_domain_value + 274
18  com.apple.CoreGraphics        	0x98b96a7c copy_string_property + 13
19  com.apple.CoreGraphics        	0x98b96a67 CGDefaultsCopyString + 32
20  com.apple.CoreGraphics        	0x98ea3c1a load_vtable + 53
21  libdispatch.dylib             	0x9461e0b5 dispatch_once_f + 251
22  com.apple.CoreGraphics        	0x98b96a45 CGCMSUtilsGetVTable + 69
23  com.apple.CoreGraphics        	0x98c64df0 CGColorSpaceCreateWithPlatformColorSpace + 13
24  net.sourceforge.audacity      	0x000257c0 wxMacGetGenericRGBColorSpace + 240
25  net.sourceforge.audacity      	0x000262bd wxBitmapRefData::Create(int, int, int) + 141
26  net.sourceforge.audacity      	0x00026417 wxBitmapRefData::wxBitmapRefData(int, int, int) + 151
27  net.sourceforge.audacity      	0x000268b7 wxBitmap::wxBitmap(wxImage const&, int) + 135
28  net.sourceforge.audacity      	0x00028b8f __static_initialization_and_destruction_0(int, int) + 111
29  dyld                          	0x8feeb0b3 ImageLoaderMachO::doModInitFunctions(ImageLoader::LinkContext const&) + 291
30  dyld                          	0x8feeb218 ImageLoaderMachO::doInitialization(ImageLoader::LinkContext const&) + 64
31  dyld                          	0x8fee72f0 ImageLoader::recursiveInitialization(ImageLoader::LinkContext const&, unsigned int, ImageLoader::InitializerTimingList&, ImageLoader::UninitedUpwards&) + 296
32  dyld                          	0x8fee7176 ImageLoader::processInitializers(ImageLoader::LinkContext const&, unsigned int, ImageLoader::InitializerTimingList&, ImageLoader::UninitedUpwards&) + 120
33  dyld                          	0x8fee73e1 ImageLoader::runInitializers(ImageLoader::LinkContext const&, ImageLoader::InitializerTimingList&) + 79
34  dyld                          	0x8fed9125 dyld::initializeMainExecutable() + 183
35  dyld                          	0x8fedcbad dyld::_main(macho_header const*, unsigned long, int, char const**, char const**, char const**, unsigned long*) + 2793
36  dyld                          	0x8fed8232 dyldbootstrap::start(macho_header const*, int, char const**, long, macho_header const*, unsigned long*) + 428
37  dyld                          	0x8fed8047 _dyld_start + 71
Thread 1:: Dispatch queue: com.apple.libdispatch-manager
0   libsystem_kernel.dylib        	0x9468f8ce kevent64 + 10
1   libdispatch.dylib             	0x9462173f _dispatch_mgr_invoke + 245
2   libdispatch.dylib             	0x946213a2 _dispatch_mgr_thread + 52
Thread 2:: Dispatch queue: com.apple.root.default-qos.overcommit
0   libobjc.A.dylib               	0x9871dfb7 (anonymous namespace)::AutoreleasePoolPage::pop(void*) + 49
1   com.apple.CoreFoundation      	0x99455daf _CFAutoreleasePoolPop + 47
2   libdispatch.dylib             	0x946212b7 _dispatch_root_queue_drain + 1209
Thread 3 Crashed:: Dispatch queue: com.apple.root.default-qos.overcommit
Thread 3 crashed with X86 Thread State (32-bit):
  eax: 0x37dcbab3  ebx: 0xe8240c89  ecx: 0xe8240c89  edx: 0xffffffff
  edi: 0xe8240000  esi: 0x9871df99  ebp: 0xb0114f28  esp: 0xb0114cf0
   ss: 0x00000023  efl: 0x00010286  eip: 0x9871dfb7   cs: 0x0000001b
   ds: 0x00000023   es: 0x00000023   fs: 0x00000023   gs: 0x0000000f
  cr2: 0xe8240000
Logical CPU:     2
Error Code:      0x00000004
Trap Number:     14
Binary Images:
    0x1000 -   0xd0dfef +net.sourceforge.audacity (2.1.1.0 - 2.1.1.0) <64207BF9-0E39-0325-FC06-58BEF6DC6BFE> /Applications/Audacity/Audacity.app/Contents/MacOS/Audacity
 0x141e000 -  0x1447fff  com.apple.audio.CoreAudioKit (1.6.6 - 1.6.6) <597AA516-9AC9-3B20-9E32-FF8BF662554A> /System/Library/Frameworks/CoreAudioKit.framework/Versions/A/CoreAudioKit
 0x145a000 -  0x1493ff7  com.apple.audio.midi.CoreMIDI (1.10 - 88) <20E11181-3421-3D46-97C0-347F68ED816A> /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
 0x14b6000 -  0x14cdffb  libexpat.1.dylib (12) <751B1CA1-D871-37AA-BE43-4131FF8B7747> /usr/lib/libexpat.1.dylib
 0x2800000 -  0x28b8ff7  ColorSyncDeprecated.dylib (442) <5910E819-D7D0-3A7B-8DAB-5833F18B43BB> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/Resources/ColorSyncDeprecated.dylib
0x8fed7000 - 0x8ff0ae03  dyld (353.2.1) <D62B782E-02ED-373D-9AD3-6D14E4FE35A3> /usr/lib/dyld
0x90008000 - 0x90443feb  com.apple.vImage (8.0 - 8.0) <56F6B317-9D70-3DC5-9868-BB6D7CB6E55D> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x90452000 - 0x90457ff7  libcompiler_rt.dylib (35) <6630682F-AB76-3E55-BE51-0A3E61B6CFC2> /usr/lib/system/libcompiler_rt.dylib
0x9045d000 - 0x90497ff7  com.apple.DebugSymbols (115 - 115) <D01FFA10-1734-31C5-B5A1-9CB61463FC15> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
0x90498000 - 0x904a6ff3  com.apple.opengl (11.1.2 - 11.1.2) <51AAC93B-7615-3D1D-A8F3-2B72C5B78467> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x90e44000 - 0x90e48ffb  libGIF.dylib (1238) <5B6FB820-8215-393E-89E5-C49A488156F7> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x90e49000 - 0x90e4cfff  com.apple.xpc.ServiceManagement (1.0 - 1) <809EF631-5E9E-3513-A017-4BAC63F6047C> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
0x90ffa000 - 0x90ffafff  libOpenScriptingUtil.dylib (162.2) <7670C29D-B3A3-3E59-A117-DD7766C07862> /usr/lib/libOpenScriptingUtil.dylib
0x90ffb000 - 0x9103efff  libGLU.dylib (11.1.2) <720B3E8B-1FC9-3431-A21A-4F00D6C9325E> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x9103f000 - 0x9104effb  libxar.1.dylib (255) <4FF7DB6F-3232-302F-94BC-F1188F78AF25> /usr/lib/libxar.1.dylib
0x9107d000 - 0x9110fff7  com.apple.CoreSymbolication (3.1 - 57020.2) <BF8232B1-6EF4-3E4C-8CF8-2FE78895A56B> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
0x91110000 - 0x91471ff3  com.apple.Foundation (6.9 - 1153.20) <B2539D54-EC35-3388-82C7-B01BB225A804> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x91472000 - 0x91473fff  libSystem.B.dylib (1213) <21396191-7FE2-398E-9DC3-0CA1DDC43EEE> /usr/lib/libSystem.B.dylib
0x91474000 - 0x9158aff3  com.apple.desktopservices (1.9.3 - 1.9.3) <544FDA55-063A-3787-A55A-A54290E4BE6E> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x9158b000 - 0x9159efff  libcmph.dylib (1) <2449B048-208E-36FB-9DFA-47E0F3BCF132> /usr/lib/libcmph.dylib
0x9159f000 - 0x915b6ff3  libLinearAlgebra.dylib (1128) <B20FAAAA-1C76-3B20-B100-5FC90F7FE023> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
0x915b7000 - 0x915c7fff  libGL.dylib (11.1.2) <92F81621-FC53-3784-81DB-A7C2C3754775> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x915c8000 - 0x916eeffb  com.apple.WebKitLegacy (10600 - 10600.7.12) <664CD921-9BA5-346E-8ABD-B707A4AE18E1> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebKitLegacy.framework/Versions/A/WebKitLegacy
0x91747000 - 0x9178eff3  com.apple.AppleJPEG (1.0 - 1) <677BE130-F5AB-36F4-A51A-1FF20FC0085A> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
0x9178f000 - 0x9181cff3  com.apple.PerformanceAnalysis (1.0 - 1) <9DF43401-98CE-3B53-B743-F6A07C6FBDC0> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
0x9181d000 - 0x91843ff7  com.apple.IconServices (47.1 - 47.1) <9C537499-B375-3F84-BF4A-EEF757FC26A9> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
0x91844000 - 0x91850fff  com.apple.CrashReporterSupport (10.10 - 631) <9A6DF8E2-AE0F-3919-889A-CD7F79ABD6EC> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
0x91851000 - 0x9280aff3  com.apple.WebCore (10600 - 10600.7.11) <87FFC08B-5131-3079-8806-94B2596F1184> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/WebCore
0x9283d000 - 0x9288efff  libcups.2.dylib (408.2) <425E4328-ECA1-31EE-B2C4-0D67FB8848BE> /usr/lib/libcups.2.dylib
0x9288f000 - 0x928acffb  com.apple.Ubiquity (1.3 - 313) <9ED23769-0725-3D4B-B7F4-AF08020D73C3> /System/Library/PrivateFrameworks/Ubiquity.framework/Versions/A/Ubiquity
0x928ad000 - 0x928d1ffb  com.apple.framework.Apple80211 (10.3 - 1030.71.6) <A133A567-C369-309C-B8BE-F43C9B1B3B61> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
0x928d2000 - 0x928d5fff  libdyld.dylib (353.2.1) <758BA99C-E4FD-3112-8E22-5D8F8065F7FB> /usr/lib/system/libdyld.dylib
0x928d6000 - 0x929d7ff7  com.apple.LaunchServices (644.56 - 644.56) <CFF2C4B8-8111-3B9B-A6F7-E2AB33163238> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x929d8000 - 0x929f3ff7  com.apple.CFOpenDirectory (10.10 - 187) <C48326FF-88D9-3E52-B896-C56401181E47> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x92d09000 - 0x92d16ff7  com.apple.speech.synthesis.framework (5.3.3 - 5.3.3) <3771942E-13BB-30C0-9992-11EE637871DC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x92d20000 - 0x92d4fff7  com.apple.DictionaryServices (1.2 - 229) <BC958000-7A7D-3C3A-B0FF-95734A35EB0A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x92d50000 - 0x92d76ffb  libPng.dylib (1238) <5CE84579-AD2F-3EBA-BC4D-7C3147C4A4E9> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x92d77000 - 0x93069ff3  com.apple.CoreImage (10.3.4) <6A0E17E6-9F56-3450-8892-670A9C489C30> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/CoreImage.framework/Versions/A/CoreImage
0x9306a000 - 0x93104fff  com.apple.ColorSync (4.9.0 - 4.9.0) <E3442A3A-181A-3C39-86D5-89292AF8115F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x93105000 - 0x9338afff  com.apple.QuickTime (7.7.3 - 2890.6) <0906D1F4-3D40-36C4-BAC1-FBBD951480B0> /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
0x9338b000 - 0x933defff  libstdc++.6.dylib (104.1) <D0EB2C99-5939-3ABA-9C18-D9AD75CE23A1> /usr/lib/libstdc++.6.dylib
0x9358e000 - 0x9358ffff  libsystem_blocks.dylib (65) <5D98F022-E863-31D4-8ADE-D53B2AE0D331> /usr/lib/system/libsystem_blocks.dylib
0x935e4000 - 0x93601fff  libCRFSuite.dylib (34) <781A92EF-410E-39B2-953D-FEE12748D834> /usr/lib/libCRFSuite.dylib
0x936db000 - 0x93975ffb  com.apple.WebKit (10600 - 10600.7.12) <5277C3B4-2BD1-3000-B01A-98521378BEEA> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
0x93987000 - 0x93987fff  com.apple.Accelerate (1.10 - Accelerate 1.10) <C2367B5B-AE20-3084-A864-104743BE478E> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x93988000 - 0x93a7eff7  libxml2.2.dylib (26) <2F37833C-4D55-3A09-9A0C-5904E8B6892A> /usr/lib/libxml2.2.dylib
0x93a7f000 - 0x93a90fff  libbsm.0.dylib (34) <C9F0C608-2794-3F6B-8078-583FC0046039> /usr/lib/libbsm.0.dylib
0x93a91000 - 0x93af5ff7  com.apple.AE (681.2 - 681.2) <530B3770-F00D-34C8-BC7D-888C7EDE9D7C> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x93af6000 - 0x93af8fff  libsystem_sandbox.dylib (358.20.5) <8F74D383-C8B0-32DD-89C1-1E99034AF763> /usr/lib/system/libsystem_sandbox.dylib
0x93af9000 - 0x93b39fff  libauto.dylib (186) <1609D0F9-6E3A-3C67-87EF-BB0BD93EDAC9> /usr/lib/libauto.dylib
0x93b3a000 - 0x93b40ff7  libsystem_networkextension.dylib (167.30.1) <1493CC7E-5018-3980-B9D6-3573EE761239> /usr/lib/system/libsystem_networkextension.dylib
0x93b41000 - 0x93b41fff  com.apple.audio.units.AudioUnit (1.12 - 1.12) <CFB6243A-1613-3468-88CE-1DDBEC1E6984> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x93b42000 - 0x93b43fff  libremovefile.dylib (35) <49DCAF7B-4466-3775-9E58-EA5D7CBA8AE0> /usr/lib/system/libremovefile.dylib
0x93b44000 - 0x93c76fff  com.apple.UIFoundation (1.0 - 1) <B5B0D178-E1F5-3625-9391-46495E35D540> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
0x93c77000 - 0x93e3cfff  com.apple.QuartzCore (1.10 - 361.19) <1E3BC4E7-7008-3802-A563-FBAB6726E332> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x93e3d000 - 0x93e93fff  libc++.1.dylib (120) <D8DE4962-66CD-3491-904E-9291EEE5E570> /usr/lib/libc++.1.dylib
0x93f0c000 - 0x93f1ffff  com.apple.Sharing (328.17 - 328.17) <71EC4FF5-C6F0-3521-BADE-E8BD71AA7741> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
0x93f20000 - 0x93f2dff7  libbz2.1.0.dylib (36) <6BC7B049-8F03-3217-9840-B1804CCBF742> /usr/lib/libbz2.1.0.dylib
0x93f2e000 - 0x93f3fff7  libsystem_coretls.dylib (35.30.2) <4F4DB31D-D7A8-359E-A742-8DBF9CA3DAE7> /usr/lib/system/libsystem_coretls.dylib
0x93fb1000 - 0x93fb3fff  libsystem_coreservices.dylib (9) <20E66A47-8D67-344A-A393-73926F0E5FB2> /usr/lib/system/libsystem_coreservices.dylib
0x93fb4000 - 0x93fb7fff  libextension.dylib (55.2) <BE3B5B43-A1BB-3BB6-9CD9-946BC61241FC> /usr/lib/libextension.dylib
0x93fed000 - 0x94017fff  libxslt.1.dylib (13) <0F55B64A-6C55-304E-ACE0-B531027AA066> /usr/lib/libxslt.1.dylib
0x94018000 - 0x9403eff3  libxpc.dylib (559.30.1) <D7E14450-D3D7-3152-A197-34DBE4533F0A> /usr/lib/system/libxpc.dylib
0x9403f000 - 0x94072fe3  libsystem_m.dylib (3086.1) <951F633F-57B7-398B-912F-F6ED4DB1C597> /usr/lib/system/libsystem_m.dylib
0x94073000 - 0x94087fff  com.apple.ImageCapture (9.0 - 9.0) <4B84B5D5-A5F3-3B35-93CE-568A73486B92> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x94151000 - 0x94152fff  liblangid.dylib (117) <34A0F807-755F-300B-B01F-AABAE3838451> /usr/lib/liblangid.dylib
0x94189000 - 0x9418fff7  libsystem_trace.dylib (72.20.1) <5F23BE77-1C60-3859-B528-C6B3C184C95C> /usr/lib/system/libsystem_trace.dylib
0x94190000 - 0x94190fff  com.apple.Accelerate.vecLib (3.10 - vecLib 3.10) <F968D12F-F59D-3148-951D-76735C3C1B57> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x94191000 - 0x941d0fff  com.apple.NavigationServices (3.8 - 215.1) <46D8B66D-CB59-36F5-BD26-FD8309337BB3> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices
0x941d1000 - 0x941d3fff  libCVMSPluginSupport.dylib (11.1.2) <81A16AA7-33F3-3B01-98C3-7996EAAEF26D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
0x941d4000 - 0x941f7fff  libJPEG.dylib (1238) <FD06EED3-936B-352E-BD74-4EF4804D9BD0> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x941f8000 - 0x941faffb  libRadiance.dylib (1238) <0D866DE4-19A4-370B-BE81-F46F6D4C8B56> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x941fb000 - 0x941fefff  libpam.2.dylib (20) <E2F34522-448A-3392-BC1D-6625BEB612B9> /usr/lib/libpam.2.dylib
0x94233000 - 0x94233fff  libkeymgr.dylib (28) <06DDCEF8-EB84-3F68-9E19-FD1A12B764FD> /usr/lib/system/libkeymgr.dylib
0x94241000 - 0x94270fff  com.apple.CoreVideo (1.8 - 145.1) <A59466FC-6B5A-3B36-BDD4-AC9CD581B7A1> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x94271000 - 0x94273fff  com.apple.loginsupport (1.0 - 1) <BA8EEAD0-8E97-3219-949B-50AE67F8869E> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
0x942c8000 - 0x94459ff3  libsqlite3.dylib (168.2) <85773EDA-5470-326B-8C21-20A80C89C96A> /usr/lib/libsqlite3.dylib
0x94569000 - 0x94569fff  com.apple.Cocoa (6.8 - 21) <6AF80DDB-C28E-36FF-BC11-D7D561AC52A9> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x94576000 - 0x9457bfff  com.apple.print.framework.Print (10.0 - 265) <7C3984BB-8337-3B90-A414-17C181A45744> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x9457c000 - 0x9461cfff  com.apple.QD (301 - 301) <4DFE3689-59DE-3FBC-806B-6A4056573E52> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x9461d000 - 0x94644fff  libdispatch.dylib (442.1.4) <B26A176C-39F7-3362-B128-27B1211068B9> /usr/lib/system/libdispatch.dylib
0x94645000 - 0x9466efff  libsystem_info.dylib (459.20.1) <91DEA2CC-26A7-32CD-ABC5-0B2754874E38> /usr/lib/system/libsystem_info.dylib
0x9466f000 - 0x94674ff7  libmacho.dylib (862) <48DE74F8-09E3-344F-A82F-665083A3BF8F> /usr/lib/system/libmacho.dylib
0x94675000 - 0x94694fff  libsystem_kernel.dylib (2782.30.5) <5A6E47DB-7090-37B3-BC5A-270211839725> /usr/lib/system/libsystem_kernel.dylib
0x94805000 - 0x94909ff7  libJP2.dylib (1238) <5AFFE3F5-BAA0-3508-8ADF-00B0517F2605> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x9490a000 - 0x949b9ffb  com.apple.Bluetooth (4.3.5 - 4.3.5f8) <95EE8D61-E8B9-3F8D-AE01-4E8DFA05AFFD> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
0x949ba000 - 0x94a15ffb  libTIFF.dylib (1238) <68A07E20-CC25-3369-AE66-E820B3634D5F> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x94a16000 - 0x94a38fff  com.apple.MultitouchSupport.framework (264.6 - 264.6) <D463A367-461B-3F8B-B73F-90C25C641843> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x94a39000 - 0x94a42ff7  libsystem_notify.dylib (133.1.1) <B8503E99-214B-3AC3-A7CA-CC837ABD7B25> /usr/lib/system/libsystem_notify.dylib
0x94a43000 - 0x94a43fff  com.apple.CoreServices (62 - 62) <08A581EC-2E8B-30CF-B555-64171C8FE5EE> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x94a44000 - 0x94a44fff  libunc.dylib (29) <CE960997-9D4A-3848-BAC7-B2255E6765FD> /usr/lib/system/libunc.dylib
0x94ae6000 - 0x94c57ffb  libBLAS.dylib (1128) <ACEF468C-5DB1-38F3-BCB2-6F3D7F2B2040> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x94c58000 - 0x94cb3fff  com.apple.LanguageModeling (1.0 - 1) <9B39E059-F48E-31AF-B1B3-B0872F362627> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
0x94cb4000 - 0x94d08ff7  com.apple.HIServices (1.22 - 523) <D4D6484B-BBB2-39E4-88D4-15D8DE050356> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x94d09000 - 0x94d0dffb  com.apple.IOSurface (97.4 - 97.4) <FD6AD351-BD60-337C-8D3D-42CDA7EE137C> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x94d0e000 - 0x950e7ff3  com.apple.HIToolbox (2.1.1 - 758.7) <A88B4B82-6C0C-300A-9703-B1CC12ED5534> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x950e8000 - 0x95442ff7  libmecabra.dylib (666.7) <55A50B97-92D3-3DDC-8E3A-58BC5FFE5E3F> /usr/lib/libmecabra.dylib
0x95443000 - 0x95451ff7  libz.1.dylib (55) <DF3B8F77-8931-3A6B-8BDF-DB67315050E6> /usr/lib/libz.1.dylib
0x95452000 - 0x955daff7  com.apple.audio.toolbox.AudioToolbox (1.12 - 1.12) <CA1E6D99-F534-3D3B-9AA5-038E171AD0A9> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x955db000 - 0x95617ff3  com.apple.RemoteViewServices (2.0 - 99) <2839C2F1-88DA-3843-87BF-441A374A8967> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
0x95618000 - 0x95621fff  com.apple.DiskArbitration (2.6 - 2.6) <D906604A-1D8C-31BF-8F22-EA219FFC858F> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x95622000 - 0x95a0aff7  libLAPACK.dylib (1128) <4E3D1289-2C98-3E53-BB8D-AD911357FF66> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x95a0b000 - 0x95b39ff7  com.apple.coreui (2.1 - 308.6) <5C418632-E00D-3864-B645-F2D993DE6455> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x95b3a000 - 0x95b41fff  com.apple.speech.recognition.framework (5.0.9 - 5.0.9) <5D268178-3812-3777-92A6-D7D3395405B8> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x95b42000 - 0x95b82fff  com.apple.Symbolication (1.4 - 56045) <BE1C4846-DA11-365D-9B46-3FF130401839> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
0x95b83000 - 0x95c00ff3  com.apple.framework.IOKit (2.0.2 - 1050.20.2) <84299E45-C5F3-365F-AC1B-0EAFF8057112> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x95c01000 - 0x95df7fff  libicucore.A.dylib (531.48) <A1002DA8-DAA9-30E8-95AE-1BF575AC5AB5> /usr/lib/libicucore.A.dylib
0x95df8000 - 0x95dfaff7  libquarantine.dylib (76.20.1) <8694AC5A-7359-3CC6-8E93-CABFCC919D4B> /usr/lib/system/libquarantine.dylib
0x95e36000 - 0x95e38ffb  libsystem_secinit.dylib (18) <3CBA3BD3-8BA2-358D-BD1A-A1C3DF5D84E6> /usr/lib/system/libsystem_secinit.dylib
0x95e39000 - 0x95e65fff  com.apple.ChunkingLibrary (2.1 - 163.6) <D5446A27-C51B-36D7-A4A1-3222A87F6F48> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
0x95e66000 - 0x95ebbff3  com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <2AF304F7-5DA4-3035-9E15-070F16700789> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x95ebc000 - 0x95efcffb  libGLImage.dylib (11.1.2) <501AE819-E4E2-335E-AAA0-4753AEB98BAB> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x968ac000 - 0x96920fff  com.apple.Heimdal (4.0 - 2.0) <08EE34A7-CF95-3CC6-A103-B8B3F304D342> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
0x96921000 - 0x9692eff7  com.apple.OpenDirectory (10.10 - 187) <A0BCF59F-87D5-3BA0-866D-4B4BF36E170C> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x9692f000 - 0x9693dff7  com.apple.SpeechRecognitionCore (2.1.2 - 2.1.2) <CDD0CAA1-DF2E-3FE1-AEE4-4C0823E6FD5C> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore
0x9693e000 - 0x969e4fff  com.apple.Metadata (10.7.0 - 917.36) <F04AED07-95EA-388D-9FF2-69E1600B9312> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x969e5000 - 0x969f1ff3  libcommonCrypto.dylib (60061.30.1) <18B9D797-34BA-3F73-8744-7812DC9AE89C> /usr/lib/system/libcommonCrypto.dylib
0x969f2000 - 0x969f2fff  com.apple.ApplicationServices (48 - 48) <76C301A4-705B-33DE-BA11-C89DCF1EDCDD> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x969f3000 - 0x969ffff7  libkxld.dylib (2782.30.5) <BAB6643C-AF3A-398B-9352-4C5F820159A1> /usr/lib/system/libkxld.dylib
0x96a00000 - 0x96a08fff  com.apple.CoreServices.FSEvents (1210.20.1 - 1210.20.1) <FDCAA783-356F-3CA4-B960-16555CD7E34A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
0x96a09000 - 0x96af5fe7  libvMisc.dylib (516) <C784D56E-112E-359F-848B-3419E0572EB4> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x96af6000 - 0x96afcff3  libsystem_platform.dylib (63) <509993B7-3F26-3360-B899-0BBB15152516> /usr/lib/system/libsystem_platform.dylib
0x96afd000 - 0x96c41ff7  com.apple.ImageIO.framework (3.3.0 - 1238) <BBD73B2F-5DF5-3304-94E1-11ABAA008C46> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x96c46000 - 0x96cdbfff  libsystem_c.dylib (1044.10.1) <9804163C-4DEC-3B94-9854-00248E44554F> /usr/lib/system/libsystem_c.dylib
0x96cdc000 - 0x96cdfff7  com.apple.help (1.3.3 - 46) <FDF183E4-3B95-3CBD-A390-2536C8E7E258> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x96ce0000 - 0x96ce8fff  com.apple.NetFS (6.0 - 4.0) <B49F5FC7-8B8D-393A-ABA1-F3214BBC7641> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x96ce9000 - 0x96cedfff  com.apple.CommonPanels (1.2.6 - 96) <955375E6-2416-38E1-AFC6-477827119329> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x96cf0000 - 0x96e06fff  com.apple.CoreText (352.0 - 454.9) <6FA9A0AE-7C82-386B-9C6D-95FA7183F919> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
0x96e07000 - 0x9723aff3  com.apple.vision.FaceCore (3.1.6 - 3.1.6) <EF92C25B-3E33-379F-A862-75C2FCA8B386> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
0x97552000 - 0x97649ff7  libFontParser.dylib (134.4) <433397B8-B22C-393A-8EA4-97C9B93EE9A0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x9764a000 - 0x9764afff  com.apple.Carbon (154 - 157) <CA90E930-DE59-3AD9-B158-3A940BA1FA8A> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x9764b000 - 0x9769cfff  com.apple.opencl (2.4.2 - 2.4.2) <B9796163-3EC0-3FAD-B4E1-F83EA2A2DD94> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x9769d000 - 0x976a5fff  libsystem_dnssd.dylib (576.30.4) <E293072C-83CC-3874-BEBC-E0D259129E1D> /usr/lib/system/libsystem_dnssd.dylib
0x977ca000 - 0x97841fff  com.apple.ApplicationServices.ATS (360 - 375.4) <7039705C-D10D-330E-B09D-69F88DC2FB9D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x9792d000 - 0x9795bff7  libarchive.2.dylib (30) <8758D35F-ADF8-30F6-8EB2-9B852876EAC8> /usr/lib/libarchive.2.dylib
0x9795c000 - 0x979d2fff  com.apple.securityfoundation (6.0 - 55126) <418A02D0-FA51-39D9-AB31-67994DC63DED> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x97a23000 - 0x97a8eff7  com.apple.framework.CoreWiFi (3.0 - 300.4) <632A811D-4706-3ED7-85E3-DD2CDB47CF8F> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
0x97a8f000 - 0x97aaaffb  com.apple.openscripting (1.6.4 - 162.2) <EC0738BF-B7D0-3C9F-9FC7-97C2D84BE644> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x97ae6000 - 0x97aeafff  libCoreVMClient.dylib (79.1) <3DB52AB1-D41E-3AC9-A355-1B6DCEDB4DFD> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x97aeb000 - 0x98717fff  com.apple.AppKit (6.9 - 1348.17) <1D891DC4-4E22-30FD-A8AC-1221531BEEA3> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x98718000 - 0x989072ef  libobjc.A.dylib (647) <7648C174-3098-3B26-AD20-490DBFFD5D4C> /usr/lib/libobjc.A.dylib
0x98908000 - 0x98987fff  com.apple.SystemConfiguration (1.14.4 - 1.14) <B23BD614-9B75-3106-83A1-959A82266D65> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x98988000 - 0x98a25fff  com.apple.ink.framework (10.9 - 213) <F47949BC-ABEE-329B-B568-71C6FEF761F6> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x98abd000 - 0x98ac8ff7  com.apple.NetAuth (5.2 - 5.2) <3E650FB0-5EB5-3807-8B71-8FAF64D6A0FC> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
0x98ac9000 - 0x98afbffb  com.apple.GSS (4.0 - 2.0) <9C593B37-1EA8-31F6-9F98-797041CA4E85> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
0x98b49000 - 0x98b86fff  libsystem_network.dylib (412.20.3) <1D1D6444-EB6B-3249-902B-1710C3C0DCCB> /usr/lib/system/libsystem_network.dylib
0x98b87000 - 0x98b8bff3  com.apple.TCC (1.0 - 1) <EE0D6865-A6E0-3BF0-93F1-837C09AA7978> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
0x98b8c000 - 0x98f83ffb  com.apple.CoreGraphics (1.600.0 - 788.2) <FB550940-AC40-3131-B4FF-4E09A588C03C> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x98f84000 - 0x98f9eff7  liblzma.5.dylib (7) <D0BC984D-5B33-328C-8F1E-7E9C41813433> /usr/lib/liblzma.5.dylib
0x99115000 - 0x99181ff3  com.apple.datadetectorscore (6.0 - 396.1.1) <178C5C3B-3896-3CE8-96C9-9244B023E256> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
0x99182000 - 0x99419fff  com.apple.CoreData (111 - 526.3) <93295B9D-6C48-3919-8B9C-A4291D3522CE> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x9941a000 - 0x997ceff7  com.apple.CoreFoundation (6.9 - 1153.18) <267B1002-C755-37B4-95CD-92358CF994B8> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x997cf000 - 0x997d6ff3  libunwind.dylib (35.3) <29D9343F-9A0A-3535-B0AE-E7CC761D95EE> /usr/lib/system/libunwind.dylib
0x997d7000 - 0x997e0fff  libGFXShared.dylib (11.1.2) <8CA7CBD7-0F4E-3052-AE20-A5DD15F74946> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x997e1000 - 0x9983eff7  com.apple.print.framework.PrintCore (10.3 - 451.1) <86895179-C54B-3D8A-B515-92DFA6315FC9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x9983f000 - 0x99a4dff7  com.apple.CFNetwork (720.4.4 - 720.4.4) <1455DB2D-6D76-3602-B9AE-C73DF873BA0F> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x99d40000 - 0x99d48fff  libsystem_pthread.dylib (105.10.1) <4A229519-29A1-3ABF-8CEF-43BCE4ACDA06> /usr/lib/system/libsystem_pthread.dylib
0x99d49000 - 0x99d4dffb  libcache.dylib (69) <55501A00-AF64-3554-8F46-8D5AFEDEC332> /usr/lib/system/libcache.dylib
0x99d4e000 - 0x99dbaff7  libcorecrypto.dylib (233.30.1) <B62C4F7C-90B1-3ECA-B5EE-3C8A3B8CBA7B> /usr/lib/system/libcorecrypto.dylib
0x9a13f000 - 0x9a140fff  libDiagnosticMessagesClient.dylib (100) <3EE83437-AA9C-356B-810B-589346B73797> /usr/lib/libDiagnosticMessagesClient.dylib
0x9a141000 - 0x9a20cfff  com.apple.backup.framework (1.6.5 - 1.6.5) <F2F66289-39DD-3033-A56B-DC8A9495C782> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
0x9a2be000 - 0x9a2ddff7  com.apple.GenerationalStorage (2.0 - 209.11) <34CF76B2-8052-359D-816D-092608FB6919> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
0x9a2de000 - 0x9a3cfffb  libiconv.2.dylib (42) <4AF77F10-0BEC-3BE0-99DF-C5170EDB316B> /usr/lib/libiconv.2.dylib
0x9a3d0000 - 0x9a3d4fff  libheimdal-asn1.dylib (398.10.1) <528D14F8-7E70-3B34-9787-5DDDAFC45E13> /usr/lib/libheimdal-asn1.dylib
0x9a3d5000 - 0x9a3deffb  com.apple.CommonAuth (4.0 - 2.0) <1968171C-084F-3E7D-B205-C0DF3409ED59> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
0x9a3f2000 - 0x9a3fcffb  com.apple.audio.SoundManager (4.2 - 4.2) <4312D0A7-4B6F-3A1E-9A47-24C6E8C65E51> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
0x9a3fd000 - 0x9a3fffff  libsystem_configuration.dylib (699.30.1) <F6CDE2CA-FFB8-3A1C-81CC-89866ABC0954> /usr/lib/system/libsystem_configuration.dylib
0x9a400000 - 0x9a419fff  com.apple.Kerberos (3.0 - 1) <92735F11-CF1C-3FA6-8682-9A30AC9E2651> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x9a424000 - 0x9a6aeff3  com.apple.security (7.0 - 57031.30.12) <3E32A87D-6A2C-3B11-87AE-4B0308F99BEC> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x9a717000 - 0x9a720fff  libcopyfile.dylib (118.1.2) <FAF3268F-C580-33D3-A5B4-74B8A8713216> /usr/lib/system/libcopyfile.dylib
0x9a721000 - 0x9a738fff  libsystem_asl.dylib (267) <85BD88AD-618E-3325-AC31-10DBAB8E9AF3> /usr/lib/system/libsystem_asl.dylib
0x9a739000 - 0x9a75fff3  libc++abi.dylib (125) <E9AF8CA1-D54D-37E3-8363-A3E8C0840F71> /usr/lib/libc++abi.dylib
0x9a7f5000 - 0x9a805ff7  com.apple.LangAnalysis (1.7.0 - 1.7.0) <DBECFAD5-DB53-390C-AE92-09549733C861> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x9b114000 - 0x9b116fff  com.apple.securityhi (9.0 - 55006) <E69C4703-1543-3604-B097-BF13D4D34C7C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x9b117000 - 0x9b224fe3  libvDSP.dylib (516) <53F7A960-01E1-3B79-A7FD-67BD19471420> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x9b225000 - 0x9b238fff  com.apple.CoreBluetooth (1.0 - 1) <153F2DDE-CCCF-3C63-AF70-2EA306DACDCD> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
0x9b239000 - 0x9b239fff  liblaunch.dylib (559.30.1) <22DF4753-F373-3678-96B8-654AB7819846> /usr/lib/system/liblaunch.dylib
0x9b266000 - 0x9b564ffb  com.apple.CoreServices.CarbonCore (1108.6 - 1108.6) <ABEA5906-26AE-308F-B078-5944ABDF94DF> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x9b565000 - 0x9b5d8ffb  com.apple.framework.CoreWLAN (5.0 - 500.35.2) <812E25B3-2041-360E-8C1D-0CCA1E66D1EE> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
0x9b5d9000 - 0x9b622ffb  libFontRegistry.dylib (134.1) <6CF6177B-D5D6-3E7B-88BC-BE833D55018C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x9b623000 - 0x9b6aafff  com.apple.CoreServices.OSServices (640.4 - 640.4) <EE22BF74-9D3F-36E0-BDF7-A3D05F3D1E69> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x9b6ab000 - 0x9b700ff7  com.apple.htmlrendering (77 - 1.1.4) <B85A63B9-C9DD-3ECC-B5DC-E12533C7FDF9> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
0x9b9a2000 - 0x9b9c1ffb  libresolv.9.dylib (57) <C2C3810A-A45E-3375-B41D-6E1BECE1BA3C> /usr/lib/libresolv.9.dylib
0x9b9ec000 - 0x9ba05ff7  libsystem_malloc.dylib (53.30.1) <1438C1B7-5CD0-3A01-ACF8-BFC4012541B9> /usr/lib/system/libsystem_malloc.dylib
0x9ba06000 - 0x9ba7cff7  com.apple.SearchKit (1.4.0 - 1.4.0) <3693A221-B615-37D4-9FB1-F5F6CC7EE1A7> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x9ba7d000 - 0x9bf25ff7  com.apple.JavaScriptCore (10600 - 10600.7.12) <5D326E0D-BE3F-3D89-8556-6C9186AAFFAC> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
External Modification Summary:
  Calls made by other processes targeting this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
  Calls made by this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
  Calls made by all processes on this machine:
    task_for_pid: 3947
    thread_create: 0
    thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=190.2M resident=52.1M(27%) swapped_out_or_unallocated=138.1M(73%)
Writable regions: Total=31.6M written=1436K(4%) resident=1724K(5%) swapped_out=0K(0%) unallocated=29.9M(95%)
REGION TYPE                      VIRTUAL
Kernel Alloc Once                     4K
MALLOC                             22.1M
MALLOC (admin)                       48K
Stack                              65.1M
VM_ALLOCATE                          28K
__DATA                             9560K
__IMAGE                             528K
__LINKEDIT                         46.9M
__OBJC                             2424K
__TEXT                            143.3M
__UNICODE                           552K
mapped file                        74.9M
shared memory                         4K
TOTAL                             365.1M
Model: iMac11,2, BootROM IM112.0057.B01, 2 processors, Intel Core i3, 3.06 GHz, 12 GB, SMC 1.64f5
Graphics: ATI Radeon HD 4670, ATI Radeon HD 4670, PCIe, 256 MB
Memory Module: BANK 0/DIMM0, 4 GB, DDR3, 1333 MHz, 0x01BA, 0x202020202020202020202020202020202020
Memory Module: BANK 1/DIMM0, 4 GB, DDR3, 1333 MHz, 0x01BA, 0x202020202020202020202020202020202020
Memory Module: BANK 0/DIMM1, 2 GB, DDR3, 1333 MHz, 0x80CE, 0x4D34373142353637334648302D4348392020
Memory Module: BANK 1/DIMM1, 2 GB, DDR3, 1333 MHz, 0x80CE, 0x4D34373142353637334648302D4348392020
AirPort: spairport_wireless_card_type_airport_extreme (0x168C, 0x8F), Atheros 9280: 4.0.74.0-P2P
Bluetooth: Version 4.3.5f8 15969, 3 services, 27 devices, 1 incoming serial ports
Network Service: Ethernet, Ethernet, en0
Network Service: AirPort, AirPort, en1
Serial ATA Device: WDC WD5000AAKS-40V6A0, 500.11 GB
Serial ATA Device: HL-DT-STDVDRW  GA32N
USB Device: Hub
USB Device: FreeAgent Pro
USB Device: Fitbit Base Station
USB Device: Internal Memory Card Reader
USB Device: BRCM2046 Hub
USB Device: Bluetooth USB Host Controller
USB Device: Hub
USB Device: USB2.0 Hub
USB Device: Keyboard Hub
USB Device: Apple Keyboard
USB Device: IR Receiver
USB Device: Built-in iSight
Thunderbolt Bus:
Actually I think it was Audacity 2.0.6 that was mostly working before (But it was occasionally crashing too). But removing the audacity.cfg files should have fixed any issue with old configurations, I would hope. I have also used the Mac disk utility in recovery mode to both fix disk issues (which it did find some to fix) as well as to fix permissions(which it also found things to fix).
But even after allowing the recovery disk utility to fix permissions and disk issues, I have restarted the machine, removed all installed audacity releases and reinstalled the 2.1.1 release, but it consistently crashes immediately on start-up.
I’m just not sure what to try next, especially on a Mac. I’m much more familiar with PC’s & trouble shooting and just learning my way around the Mac world.
With Audacity completely shut down (check in the Activity Monitor that it is not running), try deleting the pluginsettings.cfg and pluginregistry.cfg (if it exists) as well as audacity.cfg. Then try to start Audacity. Don’t load any optional plug-ins during start-up.
What happens?
I can’t find out anything definitive about that error “Dispatch queue: com.apple.root.default-qos.overcommit” but it seems to be do with a thread not exiting quickly enough.
I would go further and just delete the entire ~/Library/Application Support/audacity/ .
Do 2.1.0 or 2.0.6 from here actually launch now http://www.oldfoss.com/Audacity.html?
Just a hunch:
I’d get rid of the “FreeAgent Pro” USB driver. It’s not needed to mount your disk, and you’re probably better off without it. Unless you use the included backup software.
These drivers have a bad rep. Seagate and WD are really the same company these days. The WD version of the driver caused a lot of data loss a couple of years back when people started upgrading to Lion. And the same problem appeared again with ML and Mavericks, albeit on a much smaller scale.
I renamed the application/audacity folder to audacity211 and then downloaded Audacity 2.0.6 from the link above. Installed it and tried to run it, but it crashes very similarly, if not the same, See crash dump below.
I deleted ~/Library/Application Support/audacity/ altogether and tried to start AUdacity 2.0.6 and it gets a crash dump report. Looking at ~/Library/Application Support/audacity/ is doesn’t exit, so it must be crashing before it can even create the default config files?
Someone else suggested removing the FreeAgent Pro driver, but I’m not sure how to do that on a Mac. I’d try it if someone could give me a pointer as to how to do it.
Here is the 2.0.6 crash report:
Process:               Audacity [2383]
Version:               2.0.6.0 (2.0.6.0)
Responsible:           Audacity [2383]
User ID:               502
Date/Time:             2015-07-23 21:55:44.489 -0400
Report Version:        11
Time Awake Since Boot: 14000 seconds
Crashed Thread:        2  Dispatch queue: com.apple.root.default-qos.overcommit
Exception Codes:       KERN_INVALID_ADDRESS at 0x000000000f74f000
VM Regions Near 0xf74f000:
    MALLOC_SMALL           0000000001800000-0000000003800000 [ 32.0M] rw-/rwx SM=PRV
    __TEXT                 000000008fe5a000-000000008fe8e000 [  208K] r-x/rwx SM=COW  /usr/lib/dyld
Application Specific Information:
objc[2383]: autorelease pool page 0x14000 corrupted
  magic     0x90fffffd 0x90909090 0x90909090 0x90909090
  should be 0xa1a1a1a1 0x4f545541 0x454c4552 0x21455341
  pthread   0x5d8928ec
  should be 0xb0115000
24  net.sourceforge.audacity      	0x00023700 std::_Deque_base<Response, std::allocator<Response> >::~_Deque_base() + 39600
25  net.sourceforge.audacity      	0x000241fd std::_Deque_base<Response, std::allocator<Response> >::~_Deque_base() + 42413
26  net.sourceforge.audacity      	0x00024357 std::_Deque_base<Response, std::allocator<Response> >::~_Deque_base() + 42759
27  net.sourceforge.audacity      	0x000247f7 std::_Deque_base<Response, std::allocator<Response> >::~_Deque_base() + 43943
28  net.sourceforge.audacity      	0x00026acf std::_Deque_base<Response, std::allocator<Response> >::~_Deque_base() + 52863
29  dyld                          	0x8fe6e0b3 ImageLoaderMachO::doModInitFunctions(ImageLoader::LinkContext const&) + 291
30  dyld                          	0x8fe6e218 ImageLoaderMachO::doInitialization(ImageLoader::LinkContext const&) + 64
31  dyld                          	0x8fe6a2f0 ImageLoader::recursiveInitialization(ImageLoader::LinkContext const&, unsigned int, ImageLoader::InitializerTimingList&, ImageLoader::UninitedUpwards&) + 296
32  dyld                          	0x8fe6a176 ImageLoader::processInitializers(ImageLoader::LinkContext const&, unsigned int, ImageLoader::InitializerTimingList&, ImageLoader::UninitedUpwards&) + 120
33  dyld                          	0x8fe6a3e1 ImageLoader::runInitializers(ImageLoader::LinkContext const&, ImageLoader::InitializerTimingList&) + 79
34  dyld                          	0x8fe5c125 dyld::initializeMainExecutable() + 183
35  dyld                          	0x8fe5fbad dyld::_main(macho_header const*, unsigned long, int, char const**, char const**, char const**, unsigned long*) + 2793
36  dyld                          	0x8fe5b232 dyldbootstrap::start(macho_header const*, int, char const**, long, macho_header const*, unsigned long*) + 428
37  dyld                          	0x8fe5b047 _dyld_start + 71
Thread 2 Crashed:: Dispatch queue: com.apple.root.default-qos.overcommit
Thread 3:: Dispatch queue: com.apple.root.default-qos.overcommit
0   libobjc.A.dylib               	0x98727f13 _objc_trap() + 0
1   libobjc.A.dylib               	0x98732e00 (anonymous namespace)::AutoreleasePoolPage::busted(bool) + 152
2   libobjc.A.dylib               	0x9871dfcb (anonymous namespace)::AutoreleasePoolPage::pop(void*) + 69
3   com.apple.CoreFoundation      	0x99455daf _CFAutoreleasePoolPop + 47
4   libdispatch.dylib             	0x946212b7 _dispatch_root_queue_drain + 1209
Thread 2 crashed with X86 Thread State (32-bit):
  eax: 0xa2b51681  ebx: 0x0f74f44a  ecx: 0x0f74f44a  edx: 0x00000000
  edi: 0x0f74f000  esi: 0x9871df99  ebp: 0xb0092f28  esp: 0xb0092cf0
   ss: 0x00000023  efl: 0x00010206  eip: 0x9871dfb7   cs: 0x0000001b
  cr2: 0x0f74f000
Logical CPU:     1
Trap Number:     14
Binary Images:
    0x1000 -   0xc6efef +net.sourceforge.audacity (2.0.6.0 - 2.0.6.0) <68988B97-7D96-4DD0-9ED6-77076656CDE7> /Applications/Audacity/Audacity.app/Contents/MacOS/Audacity
  0xea6000 -   0xedfff7  com.apple.audio.midi.CoreMIDI (1.10 - 88) <20E11181-3421-3D46-97C0-347F68ED816A> /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
  0xf02000 -   0xf19ffb  libexpat.1.dylib (12) <751B1CA1-D871-37AA-BE43-4131FF8B7747> /usr/lib/libexpat.1.dylib
 0x1466000 -  0x151eff7  ColorSyncDeprecated.dylib (442) <5910E819-D7D0-3A7B-8DAB-5833F18B43BB> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/Resources/ColorSyncDeprecated.dylib
0x8fe5a000 - 0x8fe8de03  dyld (353.2.1) <D62B782E-02ED-373D-9AD3-6D14E4FE35A3> /usr/lib/dyld
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
    task_for_pid: 170783
    thread_create: 0
    thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=184.6M resident=44.2M(24%) swapped_out_or_unallocated=140.4M(76%)
Writable regions: Total=48.6M written=1404K(3%) resident=1764K(4%) swapped_out=0K(0%) unallocated=46.9M(96%)
REGION TYPE                      VIRTUAL
MALLOC                             39.1M
MALLOC (admin)                       48K
Stack                              65.1M
VM_ALLOCATE                          28K
__DATA                             9472K
__IMAGE                             528K
__IMPORT                             20K
__LINKEDIT                         42.0M
__OBJC                             2408K
__TEXT                            142.5M
__UNICODE                           552K
mapped file                        74.9M
shared memory                         4K
TOTAL                             376.4M
USB Device: Hub
USB Device: Hub
Thunderbolt Bus:
I’d try opening the installer again, just in case Seagate provides an uninstaller. Sometimes, these can be selected automatically, by pressing the alt button, while double clicking the installer.
If that doesn’t work, you’ll have to do it manually:
Follow the instruction given to uninstall Diagnostic tool.
-Go to Application Folder locate Seagate Diagnostic tool and move it to trash can so it get deleted. It will ask for password. Provide the password. Now the application is in Trash can.
-Go to Hard Drive Folder Open it. Then go to library Folder Open it. Then go to Application support folder open it.
-Now locate a folder called Seagate. Delete it by moving it to the Trash Can. If OS X asks for your password, provide it, and the folder will be now in into Trash Can.
-Close application support folder.
  • Go to LaunchAgent folder and open it. Locate the
    com.seagate.SeagateStorageGauge.plist file and delete it.
If it asks for password provide it.
  • Close Application Support folder .Then close Library folder.
  • Now Open System folder. Then open Library folder. Locate Extension folder and open it.
  • Locate Storage Driver.kext and delete it. If it asks password provide it .Now close all the folders.
  • Reboot your Mac.
  • Now emprty Trash.
Diagnostic tool will be successfully removed from your Mac.
Instructions from:
http://forums.techarena.in/windows-software/1419969.htm
You might consider a RAM test - the error you are seeing can sometimes be caused by memory errors. Cyrano probably knows alternative methods though some say the Apple memory test is inadequate.
Ram had crossed my mind too. Some third party ram that was fine under older systems started failing under Mavericks or Yosemite. These errors usually only show up with AV programs, or when copying large numbers of files to multiple locations and with bittorrent clients.
There isn’t any ram test on the Mac that’s perfect. That’s because the test program itself and OSX are running in the ram under test. If we could run the test program form the GPU, using vram memory, that would be much better. Unfortunately, a lot of laptop GPU’s use shared ram.
The best test is rember, IMHO. You can find it here:
http://www.kelleycomputing.net/rember/
Ram tests do not find all errors. And even if the test program reports errors it is wrong in very rare cases. Bitrot is always around, even on perfect ram, but it’s rare. That’s why servers have ECC error correction on ram. But that’s a rather expensive trick.
If you upgraded your ram yourself, a good test is to put back your old ram.
And if your Mac is still under warranty, it’s time to make a genius appointment and have them test ram.
I had a tester that rebooted into command line, so It wasn’t really running OS-X (that I know of). It was so stripped down (how stripped down was it?) it was so stripped down that the machine cooling went into emergency maximum based on it not being able to tell what was happening. It lost its hooks into the OS.
I don’t remember very much about it, except that if you needed multiple passes you had to put up with the screaming fans.
I’m not sure where to put this, but maybe this is part of the puzzle.
I find that I have to rename the original audacity directory then start 2.1.1. It will then run and I can either do all the setup or exit, copy back the original directory and reopen Audacity 2.1.1.
This is the strange thing - if I run a “repair permissions” on the harddrive, like before making a backup, then 2.1.1 will not open again until I go through the renaming business again. Looking at the permissions of the folder they seem normal. Any ideas what is going on here?
Cliff
I only see updates to 10.10.3.
Please attach all the .cfg files from the original ~/Library/Application Support/audacity/ (that is, after renaming that directory). To attach the files, either rename them to .txt or zip them up.
Or, does audacity.cfg in the original folder contain
TempDir=/tmp/audacity1.2-<your user name>
or a similar TempDir line containing “1.2”? If so, try deleting that line and see if Audacity will run without the renaming.
Does that repair permissions find problems and make changes? What were the changes? It should list the changes.
Not sure exactly what the problem was or maybe it was a combination of things, but it is resolved now.
Besides Audacity a few other programs had begun to crash in a similar manner while launching.
I had tried to reinstall OS-X from recovery boot, and it always seemed to hang after initial install just before restarting. I had tried several times.
So I removed and reseated the 4 memory cards in my iMac, same crashing issues & OS-X re-install still hangs at restart.
Disconnected every peripheral from the iMac except keyboard, mouse & ethernet cable. Removed 3rd party memory cards to keep original cards only.
Ran OS-X re-install from recovery boot again, but this time it worked.
Checked Audacity 2.1.1 and it ran without crashing.
Reinstalled the additional memory cards & rebooted.
Downloaded & installed rember and let it run 5 passes of the full memory checks overnight (all successful).
Reattached all peripherals & rebooted and everything seems to be back running clean again today.
So today, I was finally able to create & post the church’s podcasts from the last 2 weeks.
Thank you for the help.
Responding to Gale’s post on July 25.
Code: Select all
The audacity config did not contain the audacity 1.2 line. Actually I’m using a brand new config created by Audacity 2.1.1.
I’ll attach the config from the one that is failing and the one that always works. Basic difference is that the one that always works is just the brand new file created by 2.1.1 with no changes like temp directory, recording buffer size etc.
Note that I was thinking it was the Repair Permissions that triggered the problem, but while getting things together to respond to your requests I found that it wasn’t the Repair Permissions, but the reboot after doing so. I have just verified that by repeating it several times in a row. I’ll attach the permissions it fixed however in case those contain a clue also.
The scenario now is:
  1. With both 2.1.0 and 2.1.1 both starting normally using the config that was created using 2.1.1 in which I changed the Temp Directory and recording buffer size, I then reboot.
  2. After reboot 2.1.1 fails to start.
  3. Delete the current audacity directory. (I’m working with the entire audacity directory rather than the individual config files)
  4. copy the directory created by 2.1.1 that has no user changes to “audacity” directory.
  5. Now 2.1.1 starts just fine and I can copy back the original directory and all is well.
BUT------ In writing the above it dawned on me what the issue really was. I WAS CHANGING THE TEMP DIRECTORY FROM WHAT 2.1.1 ORIGINALLY SETUP TO A DIRECTORY UNDER “Music”. If I manually modified the config file by putting back the original directory created by 2.1.1 on startup the first time then it starts fine.
IN OTHER WORDS: 2.1.1 doesn’t like my temp directory, but 2.1.0 is ok with it. Could on startup 2.1.1 not have permission to write to my User directory?
The directory that 2.1.1 came up with on startup when there was no Application Support/audacity directory was: TempDir=/var/folders/j7/kbctfy4s28j210jlnw7g9c040000gn/T/audacity-CMac. I changed it to TempDir=/Users/CMac/Music/audacity_temp/ (note the ending “/” on the user created directory. Could that be an issue?). All was well until restart of the computer. 2.1.0 never had a problem with the directory. Seems as if 2.1.1 is doing something different in this area.
The issue, at least in my case, is definitely temp directory related. I hope the above is not too confusing, it’s clear to me in any case. :slight_smile:
Cliff
Cliff’s Audacity files.zip (57.6 KB)
Do you quit Audacity before copying back the original directory in your step 5? If you don’t do that, Audacity would still be using the default temp dir - when you quit Audacity it would overwrite your custom temp dir in audacity.cfg with its default temp dir.
It’s clear apart from my question above.
Yes, I quit Audacity before making any changes. Did the same fix on the El Capitan Public Beta and 2.1.1 runs fine now, i.e. it always opens regardless of reboots etc. It seems some code must have been changed in the temp file access for 2.1.1.
My puzzle, that hopefully someone will figure out, is: why 2.1.1 is ok with the changed user directory once it has run with the one it originally started out with UNTIL the reboot. Seems as if has to be somehow related to permissions during startup in some way, but I don’t understand the inner working of OSx enough to figure it out.
Just to throw out another puzzle, my son upgraded his Snow Leopard to Yosemite a month or so ago. He has tried to run 2.1.1 and says he has deleted the audacity folder in the Application Support directory, but 2.1.1 will not start under any circumstances and 2.1.0 runs fine. His MBP is about a year earlier than mine, but surely that wouldn’t make any difference.
Cliff
Is there a crash report or are there any error messages when he launches 2.1.1?
Does he have a “Portable Settings” folder in the Audacity installation folder? If so, have him delete that “Portable Settings” folder.
Maybe here’s your connection? If I understand correctly, you run repair permissions every time you make a backup?
This shouldn’t be necessary. And, combined with some tools, it could lead to unpredictable system behaviour. Disk utility only has a very limited knowledge about permissions. Sometimes, tools change these permissions because the need to. And when Disk utility changes these back, while that tool is running, odd things happen. The kind of thing I’m thinking about as “tool”:
  • AV software
  • DropBox
  • Uninstaller tools with background monitors
  • Safe undelete tools with background monitors
  • Disk helpers with background monitors
  • SMART, temp and other “system” monitors
  • Disk cloning tools with background monitors
Responding to Gale’s post.
cmac185 wrote:
My son upgraded his Snow Leopard to Yosemite a month or so ago. He has tried to run 2.1.1 and says he has deleted the audacity folder in the Application Support directory, but 2.1.1 will not start under any circumstances and 2.1.0 runs fine. His MBP is about a year earlier than mine, but surely that wouldn’t make any difference.
He says he gets the same Console output I was getting and still am getting when starting 2.1.0 or 2.1.1 even though they both start just fine, which is:
7/19/15 8:55:28.748 PM Audacity[1384]: WARNING: The Gestalt selector gestaltSystemVersion is returning 10.9.4 instead of 10.10.4. Use NSProcessInfo’s operatingSystemVersion property to get correct system version number.
Call location:
7/19/15 8:55:28.749 PM Audacity[1384]: 0 CarbonCore 0x90847291 ___Gestalt_SystemVersion_block_invoke + 135
7/19/15 8:55:28.749 PM Audacity[1384]: 1 libdispatch.dylib 0x9955f0b5 dispatch_once_f + 251
7/19/15 8:55:28.750 PM Audacity[1384]: 2 libdispatch.dylib 0x995600d8 dispatch_once + 31
7/19/15 8:55:28.750 PM Audacity[1384]: 3 CarbonCore 0x907c069d _Gestalt_SystemVersion + 1050
7/19/15 8:55:28.750 PM Audacity[1384]: 4 CarbonCore 0x907bf7c0 Gestalt + 150
7/19/15 8:55:28.750 PM Audacity[1384]: 5 Audacity 0x00462ae2 _Z14UMAInitToolboxtb + 50
7/19/15 8:55:28.750 PM Audacity[1384]: 6 Audacity 0x0046843c _ZN5wxApp10InitializeERiPPw + 44
Other than that I’ll have to ask him if there is any crash report or a Portable Settings folder.
Cliff
