Gal;e -
Thanks for the quick reply!
I’m a “casual user” of the computer–using it daily but not really into knowing how the operating system works, etc. I’ll try to remember what happened in answer to tour questions.
What recovery did you use, what did the message say that said you had to go back to the last state, and when did you see that message?
Did you choose the last known good version of Windows in the boot screen? Or did you do a manual System Restore back to some previous point?
Windows Update can usually cope if you have done a system restore that was reported as successful.
If you are currently able to reboot the computer and 2.0.5-alpha with WDM-KS disabled starts OK, then yes you could try Windows Update again. If Windows Update is temperamental it can sometimes help to perform only selected updates at a time, reboot, then perform the other updates.
The first time I tried downloading the Audacity 2.0.4 updates, atr the end of the download I tried launching Audacity and got the “blue screen.” I managed to delete that download using the “manage programs” function from the control panel.
I tried the download a second time, but told the computer to launch Audacity after downloading it and again got the blue screen. I think this time I went straight to the “Recovery” function in Control Panel. At the end of the recovery process, the computer flashed that the recovery was successful.
Then I tried downloading the 23 Wicrosoft updates (a few anti-virus as well as quite a few Office 2010 upadates). At the end of the download the computer went into an automatic restart. This time, however, my homescreen was “messed up”–the task bar at the bottom of the screen was in a different color from what I normally have, and a pop-up appeared in the middle of the screen, but it was only a flat rectangle and had no text on it, only what appeared to be a button to be pushed, but that was not labelled either!
Another time for recovery! After all this, I tried once again to download the 2.0.4. This time I also did a recovery. But, during my restart this time, I got a blue screen saying that the computer needed to correct (my word) the start-up procedure, and that, in trying to correct the procedure, it might have to make several passes to correct the start-up, including several restarts along the way! That “correcting the start-up” recovery also said it was successful.
At this point I’m feeling very lucky that I managed to get the computer working again–and I’m also VERY gun shy about trying any Microsoft downloads again! I dread a time when the recovery might not work and I have too much important work stored on this computer!
Thus my reluctance to try the downloads, even though MS says they are critical! Even if only one of those updates is the culprit, I still dread having to do a recovery after that download.
Do you know how I can find if any partiucular downlaods are causing problems for the users?
Again, thank you for taking an interest in these problems!
