2.0.4 crashes Windows 7 after install
I’ve been using Audacity for years, updating each time a new version is released. Just tried installing 2.0.4 on my Windows 7 SP1 computer, 12GB RAM, 1TB HD and i7 processor. It installed ok then completely crashes the system when Audacity 2.0.4 tries to start. I tried uninstalling all previous Audacity files first, same thing. I tried installing 2.0.4 with no DLLs, same thing, a massive BSD crash, which I haven’t experienced on my computer in years. It apopears to be a file called KSTHUNK.SYS that is listed on the blue screen. I’d like to go back to 2.0.3, which I’ve been using with no problems, but can’t find a download for it. Now I’m out of luck.
Scroll down to “All Previous Versions…”
Thanks, didn’t see it…
Uninstalling Audacity can be an adventure.
http://manual.audacityteam.org/o/man/faq_installation_and_plug_ins.html#win_uninstall
And you should uninstall it or the broken one may leave pieces of itself behind.
It sounds like it could be this problem: https://forum.audacityteam.org/t/audacity-start-failure-or-blue-screen-on-a-few-machines/30903/1
Please try the solution described in that post.
