I use 10.6.8…203 will NOT run. I installed both DMG and ZIP. what to do…any ideas.
Did you have a previous version that ran? If so, your settings may be messed up.
Even if you never ran Audacity before, plug-ins on your system may be interfering with Audacity launch.
To investigate and correct either case, see here:
http://wiki.audacityteam.org/wiki/User:BillWharrie/Resetting_Preferences_on_Mac .
If the problem is that Mac says Audacity is not from an “identified developer”, right-click or control-click on the Audacity application in Finder, choose “Open”, then in the dialog box that appears, choose “Open”.
I have used Audacity for a long time…years. I HAVE recently added WAVES plugs for Logic. Maybe they are the culprit. I’ll see if I can remove them. Thanks for the tips.
Waves will be the problem. You have the choice of disabling Audio Unit plug-ins in Audacity (by editing audacity.cfg) or moving Waves out of
/Library/Audio/Plug-Ins/Components/
or
~/Library/Audio/Plug-Ins/Components/
(which may stop other programs using them).
Gale, thanks for the info. It worked. I wrote an Applescript to move all plugs in both those folders to be relocated to the parent folder. All plugs I added I gave a red index color. Here is the Applescript code in case anyone else has this same problem.
tell application "Finder"
set x to display dialog "Audacity...what to do" buttons {"Open", "Quit"}
if button returned of x is "Open" then
-- Plugs in Shawn Library
set shawn_library_plugs to "Macintosh HD:Users:Shawn:Library:Audio:Plug-Ins"
set shawn_library_plugs_components to "Macintosh HD:Users:Shawn:Library:Audio:Plug-Ins:Components"
set MacHD_library_plugs to "Macintosh HD:Library:Audio:Plug-Ins"
set MacHD_library_plugs_components to "Macintosh HD:Library:Audio:Plug-Ins:Components"
set x to every item of folder shawn_library_plugs_components whose label index is 2
move x to shawn_library_plugs
set x to every item of folder MacHD_library_plugs_components whose label index is 2
move x to MacHD_library_plugs
delay 1
tell application "Audacity" to launch
end tell
else
if button returned of x is "Quit" then
tell application "Audacity" to quit
delay 1
set x to every item of folder shawn_library_plugs whose label index is 2
move x to shawn_library_plugs_components
set x to every item of folder MacHD_library_plugs whose label index is 2
move x to MacHD_library_plugs_components
end tell
end if
end if
end tell
Thanks for your contribution.
