I purchased a PYLE double cassette Deck PT-659DU. I am running Windows 7. I downloaded Audacity 2.0.3 exe.
I followed your instructions. I get Mono from the USB port. There is no 2 channel selection for USB PnP Device, there is only 1 channel. I can only record in Mono.
The external microphone is shown as IDT High Definition Audio CODEC (currently unavailable) because I don’t have an external mic plugged in.
I figured everything else out, but how to record in stereo using your software.
There doesn’t seem to be a way to make the USB PnP sound device stereo. The pull down menu only has 1 channel. 1 channel for CD or 1 channel for DVD.
How can I record in stereo with a USB PnP Sound device?
When I open the windows sound control panel and select “properties” then select “advanced” the pull down menu does NOT have a 2 channel selection. There is only 1 channel selection for CD or DVD. The controller information says USB PnP Sound Device (Generic USB Audio). Default Format - select the sample rate and bit depth to be used when running in shared mode, there is a pull down menu but the options are only 1 channel not 2 channel. So there is NO way to choose 2 channel recording.
There doesn’t seem to be a way to record in STEREO using your software. There is no selection in the windows sound control panel under properties, advanced; for 2 channel recording. There is only 1 channel for USB PnP Sound Device. 1 Channel for CD or 1 Channel for DVD.
I cannot record in stereo. I would like to record in stereo but the USB port is seen as a 1 channel microphone.
