0xc000007b
reinstalled.
restarted.
reinstalled net framework.
restarted.
run as admin.
compatibility settings set.
installed every VCredist pack I found.
and done other stuff.
I was using this program before what da hell :d
0xc000007b appears whenever I try to open it
Audacity 2.3.0 requires "Visual C++ Redistributable for Visual Studio 2015 " which may not be present on old Windows systems. You can get it from here: https://www.microsoft.com/en-ie/download/details.aspx?id=48145
installed it, still the same error.
Reboot the computer.
If that doesn’t fix it, see this topic: https://forum.audacityteam.org/viewtopic.php?f=50&t=102054&hilit=0xc000007b
