Problème d'Exportation-Export Problem
Permanent link to this post Posted by alexauda » Mon May 08, 2017 1:50 pm
Bonjour,
J'ai un problème lorsque j'exporte des pistes: lorsque j'enregistre un son (piste principale) et que je veux en rajouter d'autres donc sur d'autres pistes et avec des panoramiques, tout va bien. Seulement après avoir exporté le tout, je vais écouter le rendu et le tout est très différent et mélangé sans aucun panoramiques. Je ne m'y connais pas trop alors peut être que c'est tout bête mais voilà...
Merci
Hello,
I have a problem when I export the tracks: when I record a sound (principal track) and I want to add others with like panoramics, everything is OK, it sounds good so I export it. But when I listend to the result, it's very different and there's no panoramics. I'm not an expert so maybe it's a simple problem but...
Thanks
alexauda
Re: Problème d'Exportation-Export Problem
Permanent link to this post Posted by Trebor » Tue May 09, 2017 3:20 am
alexauda wrote:I have a problem when I export the tracks: when I record a sound (principal track) and I want to add others with like panoramics, everything is OK, it sounds good so I export it. But when I listend to the result, it's very different and there's no panoramics. ...
There are two export options in the file menu : "export audio" & "export selected audio".
If you want all the tracks to be included, (not just the selected tracks), use "export audio".
Also make sure no tracks are muted, as muted tracks will not be exported.
Trebor
Return to Français
Who is online
Users browsing this forum: No registered users and 3 guests
